Results 1 to 10 of 10
Thread: Regular 225 Opti vs 250 Opti XS
04-10-2007, 11:40 AM #1
Hello,
could you help me to find out the difference between the Optimax 250XS and the regular Optimax 225? The 225 is the biggest Optimax available in Austria. I would like to have a bit more power for my 21´cat. Both engines are the 3L blocks, the 250 turns some 250 RPM more (the LU is different). Is there a easy way to get the 250 HP from the 225?
Thanks for all hints.
Roman
Vienna,Austria
04-10-2007, 12:39 PM #26000 RPM
- Florida
- 1,881
It's a bit more than 25 hp difference.
jim
04-10-2007, 01:26 PM #3
Would you happen to have that curve chart for the 225 Pro XS??
Support Our Troops!
04-10-2007, 10:08 PM #46000 RPM
- Florida
- 1,881
Sorry
04-14-2007, 08:21 AM #55000 RPM
- Fremont, WI
- 362
quick differences between 225 opti and 250XS:
liners
pistons
cylinder head
those differences alone make it economically unfeasable to try and upgrade
04-16-2007, 01:42 AM #6
Jimmyb,
thanks for the hint.
01-31-2018, 10:26 AM #75000 RPM
- Mar 2004
- vonore tn.
- 225
- 21
- 28
also most xs motors run higher fuel & air pressures than stock motors. & rpm limiters are 500 rpm higher making more hp.
02-01-2018, 02:31 PM #8Member
- Jul 2010
- edmonton Alberta
- 48
- 11
02-04-2018, 02:38 PM #95000 RPM
- Mar 2004
- vonore tn.
- 225
- 21
- 28
the engine blocks come down the same assy. line, on the newer motors. the only diff. is black inj,s that run 105-90 psi on xs motors & the ecm.
02-06-2018, 03:28 PM #105000 RPM
- Mar 2009
- Seymour, Tn
- 176
The 250 XS motors have a higher port timing, carbon fiber reeds, higher air & fuel pressure and Gray injectors. They only also have different fuel and ignition curves and higher rev limit. Only the outside of the blocks are the same.
