Results 571 to 585 of 726
Thread: Merc V6 History
08-15-2019, 09:02 PM #571Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
What year was tbe first looper inline?
08-16-2019, 05:48 AM #572
1988
08-16-2019, 03:38 PM #5735000 RPM
- May 2013
- Pickett, WI
- 210
- 19
- 86
- 362
- 210
08-16-2019, 04:09 PM #574Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
They are tuff motors.......Just keep the carbs clean.... and they will out last 3 lowers.........
08-16-2019, 04:12 PM #575Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
The early ones.... had a habit of pulling the sleeve into the crank. When piston taper got big.... not good.
Capt.Insane-o liked this post
08-16-2019, 04:19 PM #576Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
Rckid 74..... were you behind the L4 66 cid motors adjst on the exhust port to make it think....pulse tunning/ also the 2/4 gousse neck... into a 3 cly mid? I ask because you did the V4... 60 and tried to fool it......120/0 ......2 bang....
08-16-2019, 06:43 PM #5775000 RPM
- May 2013
- Pickett, WI
- 210
- 19
- 86
- 362
- 210
08-16-2019, 08:40 PM #5785000 RPM
- May 2013
- Pickett, WI
- 210
- 19
- 86
- 362
- 210
This thread is supposed to be about the V6 so maybe the administrators will not be too happy about me expounding on the inline 4 looper here. I'll try it anyhow.
The story about the big I4 is not so much about the design and development of the engine ( that was pretty much straight forward) as it is about how it got that 2-by-4 moniker.
After going thru a couple of different exhaust systems, the one we ended up with gave us an honest 115 HP, and everything looked good till we got it on a boat and started exploring the entire throttle range. All was nice and smooth till you came down to about 2300 RPM and then it got really ratty and stayed that way on down to idle. I just thought it was a carburation problem at first so we set our carb expert to work on it. Time went by and he got it a little better but still no where near good enough for production. In the meantime production dies and tooling were being made, we were gearing up for a quick introduction but the dam thing would just not idle or off-idle. Even Jordan was on my back to get the line started. So I, along with several others, was down on the river one day trying to come up with something when (as I was adjusting the low speed needles), all of a sudden the engine broke into the nicest idle you ever want to see. Sat there just pug-pug-pugging away. I thought wow!! What happened. I called over John Litgen to show him. He was amazed too but after awhile he says, "I think its idling on just two cylinders". So we started pulling plug wires and sure enough cyls 1&2 were dead. I had leaned out those two cyls to the point they quit but 3 & 4 were still good. Man was I disappointed. ---- But after awhile I got to thinking why not try to promote that and see what happens. So I idle out of the slip - punch it and blaaa - nothing. Those two cyls would just not light up. It was obvious -- they had leaned out and dried up the crankcase to the point where there wasn't enough fuel in there to act as a acceleration pump. OK -- so lets just add an acceleration pump to those two cyls - actuate it by the throttle linkage - and we're all set. And that's what happened. We made it into production - a little late - but I could stop sweating. And that's how the 2 by 4 came about. 2 cylinders at idle and off idle -- 4 cylinders everywhere else.
I guess it went over fairly well. I didn't hear a lot about it from the field except that the commercial fishermen really liked it because they do a lot of idling around while working their nets and this engine was super efficient at idle. Just sipped fuel.Last edited by rckid74; 02-21-2020 at 05:10 PM.
Never up --- never down!!
08-16-2019, 08:56 PM #579Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Thread up man
08-16-2019, 09:04 PM #5805000 RPM
- May 2013
- Pickett, WI
- 210
- 19
- 86
- 362
- 210
08-16-2019, 09:12 PM #581Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
I'm going to do something boring like start the thread with a bunch of patent diagrams etc later on if I'm not sleeping. I like the motor and it would be an interesting thread.
08-16-2019, 09:24 PM #5825000 RPM
- May 2013
- Pickett, WI
- 210
- 19
- 86
- 362
- 210
FMP thanked for this post
08-17-2019, 07:46 AM #5835000 RPM
- Nov 2005
- Lake Eustis fl
- 109
- 33
True story, I remember it well
rckid74 liked this post
08-17-2019, 02:33 PM #584Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
I was called by a guy with one.....used.... it had a rattle.....at top end. Sounded like a 2cly motor bike......Ringadinnng....Drove me crazy.......Some one had stacked the main jets......upside down. And any thing Merc history you can post is welcomed.
08-17-2019, 03:09 PM #585The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19216
- 3 Post(s)
