Results 226 to 240 of 726
Thread: Merc V6 History
04-05-2014, 11:20 AM #2265000 RPM
- May 2013
- Pickett, WI
- 210
- 19
- 86
- 362
- 210
04-05-2014, 11:44 AM #227
Its a Julian date.
04-05-2014, 07:26 PM #2285000 RPM
- May 2013
- Pickett, WI
- 210
- 19
- 86
- 362
- 210
WillySteve liked this post
04-05-2014, 09:41 PM #229Member
- Feb 2010
- Minocqua
- 97
Sweet, where were the pictures taken, was it Fond Du Lac?
04-06-2014, 09:21 AM #230The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19220
- 3 Post(s)
04-06-2014, 09:56 AM #231
04-06-2014, 10:50 AM #2325000 RPM
- Jul 2004
- ontario
- 182
- 18
- 59
- 24
Wow, best thread ever. I just read the whole thing, start to finish. Great job, thank you!!!
04-07-2014, 09:48 AM #233
I will say it again... The best read ever on S&F!! Thank you and keep it coming!!!
'97 Allison XR2001rr / 2.5 Merc
04-07-2014, 04:21 PM #2345000 RPM
- May 2013
- Pickett, WI
- 210
- 19
- 86
- 362
- 210
These pics were taken at plt. 6 in Oshkosh. Sorry about the duplication. I’m not very computer savvy so probably hit some wrong buttons. I had wanted to post these back when I was talking about Old Blue but couldn’t find them. A couple days ago I found them while rummaging thru some drawers upstairs.
Now that I look at them closer, I see that only the first picture is of Old Blue. The others showing an engine on the propshaft dyno are of one of her sisters. The block is not dark blue.
Here are a few more of the same engine and showing more of the dyno hookup.
Attachment 295709Last edited by rckid74; 04-08-2014 at 02:00 PM.
Kitch thanked for this post
04-17-2014, 10:00 PM #2355000 RPM
- May 2013
- Pickett, WI
- 210
- 19
- 86
- 362
- 210
There was nothing very unusual about the undercarriage. Between the powerhead and driveshaft housing were two adapter plates which trapped the upper mounts and also received the water from the pump and distributed it to the main inlet and some drain holes. A little was also sprayed into the exhaust to help boost the bottom end power. The exhaust extenders were bolted to the lower plate and dumped the exhaust into the exhaust collector tube which also formed the wall of water between it and the DSH.
As I recall, the gearcase was beefed up a bit but otherwise was typical Mercury.
The clamp bracket assembly was all new but at that time still used the hydraulic trim system with the pump inside the boat. Normally the hydraulic lines went from the pump, over the transom, and down to the trim cylinders. And yes, it was me, who had the bright idea to simplify that by drilling through the lower mounting bolts and routing the hydraulic oil from the pump, thru the bolts, and then connecting the outer end to the cylinders. Very neat and tidy. Well I should have stuck to engine design and kept my nose out of an area I knew nothing about. I had never mounted an engine on a boat in my life and didn’t realize that these bolts get pounded into holes, that didn’t quite line up, with big hammers and that silicone sealers were pumped into the holes first. These things were not conducive to making a good connection. Needless to say, a redesign was hurriedly put in place.Last edited by rckid74; 04-22-2023 at 02:23 PM.
04-22-2014, 07:20 AM #236Team Member
- Oct 2013
- rowley MA
- 291
- 16
Read all the pages and couldn't get enough very awsome
04-22-2014, 08:58 AM #237Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
I remember those bolts.
They should have been shipped with bronze nuts to prevent the SS ones from gauling/picking up ( even when lubed)
04-22-2014, 09:42 AM #238
I have quite a few sets of those bolts, they were a great idea until the ham fisted bozos got a hold of them like said above.
04-22-2014, 09:45 AM #239Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
yep good idea just needed to be shipped with bronze nuts
04-22-2014, 12:00 PM #240
I had never seen the thru bolt until about a year ago when Rock showed em to me. Great idea but the application was not quite ideal. Thanks again for these posts. I'm loving it.
Sunsation 32 Dominator - 496 MAG HOs
Nothing runs like a Deere when a CAT's on it's ASS!
