Results 1 to 3 of 3
Thread: coolant hose discharge
04-08-2007, 09:30 PM #1
why doesn't each head dump the coolant water overboard instead of the water going from one head, through a hose, to another fitting...just to be joined up with the coolant water from the other head and dumped overboard?
Best regards,
David
1989 Lavey 20.8 Sebring Mod-VP
formerly DEAD 1995 2.5 Mercury with carbs.
Now, 2.4 200 as it came from Mercury...Stock!
22" small hub HighFive
5900 rpm fully loaded down with friends and cooler
6200-6300 rpm with me alone.
We ski, tube and pleasure boat
04-09-2007, 08:34 AM #2
It ain't a dump, it's just a sample pee stream to reassure you that there is water getting to the engine. That's all it's good fer.
hope it helps
John
04-09-2007, 06:52 PM #3
They are nothing more than air bleeds, water goes up to top of block then through top of head, then back down and out, just a good way to eliminate air pockets, hot spots. what ever you do don't drill out the hole in the disc's any bigger than stock(1/8"? been awhile since I looked at one) any extra water flow out, is lost cooling.
Jeff
is gone
