Results 1 to 6 of 6
    Dec 2006
    Plano, Texas
    transom repair advice needed
    My boat has an aluminum plate on both sides of transom. When new, it didn't and offset mount dug into transom, thus the last owner adding outside plate. Well, that plate is being replaced and I want to do some 'glass work on it before reinstalling. Suggestions are welcomed.
    inside looks fine....plate and wood.
    Best regards,
    David
    1989 Lavey 20.8 Sebring Mod-VP
    formerly DEAD 1995 2.5 Mercury with carbs.
    Now, 2.4 200 as it came from Mercury...Stock!
    22" small hub HighFive
    5900 rpm fully loaded down with friends and cooler
    6200-6300 rpm with me alone.
    We ski, tube and pleasure boat
    Feb 2005
    seattle
    if the plate is digging into the gel, it sounds like the tramson could be rotten. if so you need to replace it.
    here's my suggestion and if search this the attached site there is another method.
    http://www.hydrostream.org/ArticleArchives/Transom.htm
    but you need to put the plate back again with this method.
    Dec 2006
    Plano, Texas
    Quote Originally Posted by hsbob View Post
    Laveycraft clarified what happened to mine (and others they sold). The offset bracket tends to dig in at the bottom since outboards pull from upper part of mount and dig in on lower. Later on, plates were installed to spread the load out. Mine was retrofitted. I will further investigate the wood and glass over damaged area. New plate made.
    Best regards,
    David
    Dec 2006
    Plano, Texas
    repair fixed with new transom plate and 6 layers of 'glass
    Best regards,
    David
    Feb 2005
    Muskoka Canada
    That hydrostream artical is a NONO in the glass world, never cut the outside skin!
    2023 TUFF 25
    Dec 2006
    Plano, Texas
    Quote Originally Posted by RBT View Post
    thank God I didn't do that... just scuffed up outside skin, cleaned it, then glasssed over cracks. Wood in good shape, new plate had edges sealed to transom with Marine Goop and looks fantastic.
    Best regards,
    David
