Page 2 of 9 FirstFirst 1 2 3 4 5 6 7 8 9 LastLast
Results 16 to 30 of 127
    JUPITER, FLORIDA
    Matt, sounds like a lot of fun!! I would rebuild using composite materials so you will never have to worry about rot again. High Density Mantex for the transom and stringers will keep the boat light and indestructable. If you need any help I've got the right guy to do the work in Pompano Beach. PM me if you need his number. Steve
  2. #17
    Dec 2006
    Mt. Laurel, N.J.
    sign me up whats the link to the company
  3. #18
    Jul 2002
    South Florida
    Found the rubrail by searching on google, http://www.wefcorubber.com/extrusion..._rub_rails.asp .
    Took the boat off the trailer and flipped it to make the jig. The pad is pretty flat, within 1/16" over the aft 3'. A little dip about 6" fwd and another about 30".
    The pad is 7.25" wide and right around 7' long depending on how you measure it.
    Have the first station roughed in but needs some fine-tuning.
    Attached Thumbnails Attached Thumbnails upside_down 001 (Small).jpg   upside_down 007 (Small).jpg   upside_down 012 (Small).jpg
    78 Hydrostream Vandal - under restoration here: VANDAL RESTORATION THREAD
    86 21' Eliminator Daytona
    17' Badetta sandbar skiff
  4. #19
    Jul 2002
    South Florida
    Finished building the support fixture. I was having a hard time getting the wood to match the hull, so I bedded it in a fat bead of silicon seal to take up any gaps.
    Also pulled the rubrail while it was upside-down. Couldn't cut them off, tried grinding them but they still wouldn't pull through the aluminum. I ended up pulling the rubrail off with pliers. The deck is fine, but on the hull half of the rivet heads pulled through the fiberglass, and the other half pulled through or broke the aluminum. Also a good portion of the forward end of the deck is not bonded at all to the hull, so it looks like we'll have to pull the deck altogether. That will make getting the rest of the rivets out a lot easier, and also repairing the forward hull and the flange where the rivets were.
    Now comes the messy part, cutting & grinding all the old wood and fiberglass out. It'll probably be a couple weeks before I can get started on that.
    Attached Thumbnails Attached Thumbnails jig 001 (Small).jpg   jig 004 (Small).jpg
  5. #20
    Jul 2004
    Fort Lauderdale, Florida
    Big Improvement
    She sure looks prettier upside down!
    Per Rock:
    "Once I bought my first Hydrostream boating changed forever for me."
    Per my hero Instigator:
    "I try not to let common sense interfere w/my boat buying decisions."
    Pat Gent
    cell 954-249-3246
    '78 Hydrostream Vandal (being rebuilt)
    '86 21' Eliminator Daytona, 300 OMC V-8 (Li'l Toy III)
  6. #21
    Jun 2004
    Lakeridge NY
    Now that is an awsome boat to do a resto on. The Vandal and Venturas are worth the time. Good luck Matt.
    (Apricot)
    Hydrostream Ventura II/Merc
    (sold)
    (Bruiser Scheme)
    Hydrostream Viking/Merc
    (sold)
    (tri color letdown scheme)
    Hydrostream Valero/Merc
  7. #22
    Jul 2002
    South Florida
    So now the itchy time begins.
    Once I got the rubrail off I decided to split the deck off the hull. It was open in the front anyways, and it makes it much easier to repair the deck and the fwd portion of the hull.
    I ran a thin sawzall blade up in the seam. It was glued with resin in a few areas, glued with some kind of flexible black adhesive in others, and not attached at all in some places.
    I cut out the splashwell to release the deck at the transom, as I won't be keeping the splashwell anyways.
    Attached Thumbnails Attached Thumbnails split_deck 003 (Small).jpg   split_deck 001 (Small).jpg   split_deck 002 (Small).jpg
  8. #23
    Jul 2002
    South Florida
    The deck might weigh 75 pounds, its pretty easy to pick up and move around. It has some thin core running up the flat center section, and 1/4 inch ply along the gunnels.
    Not sure what to do with the deck while its off the boat, need to find somewhere to store it.
    We're making it center-steer. I'm considering cutting out the hump for the steering on the right side, or maybe even cutting out both dished areas and filling them in flat for a more sleek look. The splashwell is getting filled in flat and I'm adding a small fairing in front of the engine.
    Attached Thumbnails Attached Thumbnails split_deck 008 (Small).jpg   split_deck 010 (Small).jpg   split_deck 012 (Small).jpg
  9. #24
    Virginia Beach
    killing me!
    Matt, you're making me want to go get another Vandal!
    I have too many project boats in the works now!
    Maybe I'll sell my Viking when it's done and get a Vandal.
    JT
  10. #25
    MCHENRY, IL
    cool keep the pics coming! makes me want to do work on mine
    John E.
    HydroStream Vandal 140 EVINRUDE 69mph GPS
    Black'99 SVT Lightning #1767 of 4000
    If It Ain't Blown It Sucks!
  11. #26
    Nov 2004
    LEBANON OREGON
    Quote Originally Posted by 87 hydro200 View Post
    hey fellas! i am a bit new to your forums but let me say there great!!
    i was looking for a little help. i recently bought an 87 Hydrostream with a 200 merc. the windshield was missing and i was hoping that someone out there might be able to help me locate a replacement or an aftermareket upgrade. thanks for any guidance in finding one. i can be reached at my email address rickysroofs @ bellsouth.net Thanks Racing Rick
    which hydrostream..... there were about as many windshilds as there were boat modles...
  12. #27
    Apr 2007
    louisiana
    hey 150. thanks for the info. my hydro is a viking 17.5 ft. i will have some pics posted real soon. i got her for a song and boy am i loving every minute of it..
  13. #28
    Dec 2006
    Mt. Laurel, N.J.
    i need a windshield for my viking too
  14. #29
    Jul 2004
    John--When it's done, come down for a ride
    Not sure where you are right now, but once we (Matt) get the Vandal done, we need to drag you down to River Ranch or one of the other get togethers and reunite you with her.
    Per Rock:
    Pat Gent
    cell 954-249-3246
  15. #30
    Jul 2002
    South Florida
    Thinking about what engine is right for this boat....started a thread here:
    http://forums.screamandfly.com/forum...d.php?t=130127
