Results 1 to 2 of 2
01-10-2007, 09:40 PM #15000 RPM
- Jan 2005
- levitown
- 696
2.5 want to use metal cage bearings,whats the part numbers
1996 2.5 200 hp . the motor uses all plastic cage bearings . when i look at doug russell part numbers i think their may be 10 different numbers for the connecting rod to crank bearings . i am using the stock 644-818141 rods small bolt . i would also like to change the two middle main bearings , the block seriel number is og507568 any help with the part numbers ????????????????
01-11-2007, 07:43 AM #2
31-16756a6 is the number for the center mains and 31-17514a1 is the good metal cage bearing number for the top guided hi perf rod bearing. hf...
