Results 1 to 2 of 2
01-05-2007, 06:10 PM #1
Aluminum rims, hubcaps and trailer tires.
Has anyone had slow leaks with thier aluminum rims? I found out aluminum corrodes over time and the bead needs to be cleaned up. For a boat trailer this seems too much bother. Not to mention the cost.
Anyone running cheap hubcaps to dress the steel rims up? Any problems?
Is there a ricer problem with using hubcaps on a trailer?
Any difference on cheap trailer tires and expensive ones? I don't have the need to put megamiles on the tires so they will probably dryrot before road wear. I understand there is a big diff between passenger tires and trailer tires though.
When I went to move my boat into the garage discovered the 'bad' tire is BADD!. Theres a hole in it big enough to argue with the compressor.'90 STV
'96 260
under construction
for far too long
01-11-2007, 06:48 PM #2
I've had cars leak, pontiacs are famous for it...key is they do it when you don't drive them. If you drive it regular then they don't leak. I have stored one and it leaked and soon as I drove it...it stopped. It is corrosion in the bead. I have used hubcaps on trailers no problem. I even got a set for a 4x4 truck once, and I holesawed the center to fit the 4wd hubs, I am sure you could do the same if bearing buddies stuck out that far. They were plastic.
I don't know about trailer tires. I use old truck tires. They passed a law here against that now, but I still use them. I have used car tires for a trailer that weighed half what a car did loaded, like a small boat, but for nothing more. IMO a people tire is going to be better for its weight rating than a non-people hauling tire. If I have a trailer with trailer tires like something new, I would keep the same on it.
