Results 1 to 7 of 7
    Feb 2005
    washington, mo
    Question Jet boats and fish finders
    Guys give me your ideas or setup for my 16' Weldbilt/60hp Merc Jet with a fish finder.
    I'll only occasionally use it on small lakes or deep holes on the river so I want a low price model but what about the transducer? Do you have yours rigged so it can be removed easily while running the shallow riffles?
    Or should I opt for a clamp on battery operated unit? I've never had one before but wanna try one this year as we have a nice little conservation lake close by now that I'll be fishing too.
    THANKS!
    WASHINGTON N.C.. I TOO HAVE A BOATING PROBLEM
    I epoxy mine to the inside of the hull near the rear, (and yes, even the ones that are supposed to go on the outside rear of the hull will "shine" thru the hull.
    Can't use silicone or anything that will be full of bubbles, it must be a solid, (no gaps, voids) installation.
    Test it before glueing in, by putting some water in the bottom of the hull,( on the very outer hull, not the inside floor), and move it around till it reads......mount it as rearward as possible.
    JOHN MASON
    '83/VECTOR/MERC 200-- SOLD
    '98 Quartershot T-3/ MERC 200
    "If your not living on the edge, your taking up to much space"
    Mar 2005
    current river missouri
    you can mount it on the rear transom of the boat as long as it is flush with the bottom or a little bit raised off the bottom. im not saying that it wont, but i havent heard of them reading through the boat.
    SEATTLE WA.
    through hull
    I use a through hull transducer. I just dont know if they work on aluminum boats. I have one on My STV Euro, but I looses signal at about 50 mph depending on how deep the water is. It looks like a small hockey puck glued to the bildge.
    Lance
    2005 TRIAD STV EURO
    421 HP OMC 3.3 EFI by STOKER
    16" Taylor mid, Merc sporty
    Dec 2001
    Sunbury, Pa
    I think mine said it wont shoot through on aluminum hulls.
    Ralph Musser
    27' Fountain Fever W/ 525SC
    22' Rapid Craft W/ Evinrude 300 V8 January 2009 BOAT OF THE MONTH SOLD
    24' Triton 240 Gold W/ Mercury 60
    14' Royalcraft W/ Evinrude 75 father/daughter project
    Aug 2004
    Hillsboro MO
    Quote Originally Posted by jetriverfish
    THANKS!
    Check out the Alumaducer from http://vexilar.com
    Jul 2011
    Gloucester, VA
    Quote Originally Posted by WATERWINGS View Post
    Quote Originally Posted by river_ratj40 View Post
    Both of these. Epoxy it inside or mount it on the transom flush or up. If you put it up it will not read while running.
