Results 1 to 10 of 10
Thread: octane booster
    Jan 2006
    Champaign IL
    octane booster
    what everybody thoughts on octane booster? I was told to run Moroso or any ether based kind.
    Having played around extensively on the dyno with a 650hp 428 pontiac, apples to oranges I know. Nothing worked better than a mix of race fuel and normal gasoline. The **** that comes out of a little plastic bottle is a serious crap shoot.
    phoenix, az
    You can do a search on octane booster and get all the rants and raves you could ever ask for. The only thing some people swear by is TK7. Look it up under the search function.
    May 2001
    Hickory NC
    Two strokes dont seem to like it much, my feeling is the oil affects it. Much safer to run a mix of pump and race fuel
    phoenix, az
    I haven't tried the TK7 personally, just read about it here on S&F. I just stick with AV gas. Once you get past the different look/color on the plugs/heads, it works fine.
    Everett, Washington
    Does anyone know of a good octane booster that will mix with oil? I am limited to runs that I can make it back to the ramp without refueling. I can carry 120 gallons, but even that will not carry me through some of the runs. The marinas on the ocean only have 87, my motors will pop with anything less than 91.
    1990 Cougar 25 MTR w/twin 300 PM's
    Moline,Ill
    Never tried it with 2-stroke, but I have good results with lucas octane booster in my '65 plymouth, mildly built 440 w/ a lot of timing.
    Jeff
    is gone
    May 2005
    Greenville, NC
    Quote Originally Posted by Propster
    Blendzall.
    Ló fasz racing
    Joe Horvath
    Feb 2005
    seattle
    you may look in the LnS web page they had a booster than would work some on 2 strokes.
    Nov 2005
    Malta, Europe
    I would use race fuel mixed with pump gas , just enough to get you above 91 octane , thats the safest way
    octane boosters( if they really work ) wont put you from 87 to 91 octane ,
    I dont think its worth risking the engine for something you'r not 100 percent
    just my opinion
    18 ft Speedcraft - Offshore
    Bottle Fed Merc tuber 2.4
