Results 1 to 7 of 7
11-17-2006, 09:07 PM #1
Mounting Brucato PCU on stock ECU bracket-- how I did mine...
I can't fit any more damned wires or harnesses through my stbd side wire loom, and there's already too much stuff on the other side, so I decided to mount my new-to-me Brucato PCU on the engine.
(Thanks for your help on the phone Tony, and for sending me the correct fuel curve. )
I wanted to use the stock ECU bracket shock mounts, but they're permanently tapped into the aluminum base plate, and they're too far apart.
I cross-drilled the rubber shocks a couple more times with a high speed drill bit (stinky) to soften them up for the lighter electronics. I visited my local ASAP machine shop and they found a nice piece of 1/8" aluminum on the scrap shelf. They punched it to the size I needed, parts and labor, $10.
I ground a deep notch into the side of my adapter plate to clear the harness connector bracket, taking into account any flexing of the shock mounts. I drilled holes for the 3 mount studs, and four for the PCU. I rounded off the corners and cleaned up the edges, and did the sandpaper-twisty-thing to hide the scratches. I used stainless steel nylock hardware with thin washers to fasten the PCU to the adapter plate. I found that you have to grip the shock mounts gently with slipjoint pliers while tightening the nylock nut, then give it a little twist before fully tightening, to prevent any twisting of the rubber.
Whadd'ya think?Last edited by pyro; 11-17-2006 at 09:11 PM.
11-18-2006, 01:23 PM #2
looks good,should work great
TRANSPORT SERVICE...UP TO 36 FEET....YOUR TRAILER OR MINE... FULLY INSURED...............
DOT & CDL COMPLIANT $500,000.00 CARGO & 1 MILLION LIABILITY.
LIVE LIFE ON THE EDGE, LESS CROWED BETTER VIEW
11-19-2006, 09:34 AM #3
PCU mounting
I used a piece of polyethylene from an IKEA cutting board to mount mine...
11-19-2006, 10:23 AM #4
That's even better yet! Super cheap!!
11-19-2006, 11:49 AM #5
Looks nice Pyro! I think there are more people than you think that would just as soon mount it in the stock location. I have been pondering the same things for my 260. The plan is to give the STV a PCU for Christmas. That was my dilemma "where to put the PCU" Have you had a chance to try it?
Craig16' Inland TigerShark Flatbottom/
1978 Merc1400withXS Mid
coming soon: 2.4 220 Lazer EFI/Marty Powell 15"mid
1988 Weeres 24ft pontoon/30hp Evinrude party barge
1991 STV Pro Comp/Mercury 1996 2.5 260
11-19-2006, 01:25 PM #6
Nope, next spring...
11-19-2006, 01:48 PM #7Originally Posted by Markus
