Results 1 to 10 of 10
Thread: evenrude etec-help please
09-14-2006, 02:19 PM #1New Member
- Aug 2006
TRADED MY 90HP -2 STROKE -2004-JOHNSON FOR A 90 HP EVENRUDE ETEC.
JOHNSON (WOT-5300 RPM-40MPH)
EVENRUDE(WOT-4300RPM-30MPH)
SAME-BOAT-SAME PROP-SAME HP-SAME -GEAR REATIO
PROP-13 1/2 X17 PITCH S.S.
TRYED 13 1/2 X15 PITCH ALUM.-(WOT-5000RPM-32.6MPH
ANYONE HAVE ANY IDEAR WHERE I SHOULD GO NEXT
HELP-THE FISH ARE IN--PETE
09-14-2006, 02:23 PM #2
where to go ?
[QUOTE=petedibenedetto]
Merc lol
Sorry, somebody was going to say it.2005 TRIAD STV EURO
421 HP OMC 3.3 EFI by STOKER
16" Taylor mid, Merc sporty
09-14-2006, 02:35 PM #35000 RPM
- Jul 2003
- Wisconsin
- 367
Try asking here. They have had so many problems with E-tec on this board that someone is sure to be able to help.
http://bbcboards.zeroforum.com/zeroforum?id=51
I'm sure any Merc dealer could help you out also.Better to be silent and thought a fool, than to speak and remove all doubt.
09-14-2006, 02:41 PM #4Junior Member
- Sep 2006
- Gun Lake, MI
- 11
Have you tried and other props? We had a 90 Evinrude and could never make it run right. Hung it on the board out back and it's still there even though the rack fell over. No one could make it run right, not even Evinrude. There is a place by Detroit Michigan that may be able to help you, they specialize in E-Tec and FICHT. If I find there info I will post it.
09-14-2006, 03:50 PM #5Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
Check your engine height it should be with in a mile or 2 not what you are seeing. Did the dealer do the install and set up with a lap top to verify the engine?
09-15-2006, 06:00 PM #6New Member
- Aug 2006
the dealer did the install -they were trying diffrent props -they gave up an told me to pick up my boat and try some props on my own-what up with that?? they charge me $585.00 and did nothing -not to happy-and diappointed in the new etec.i dont understand your answer?
pete
09-15-2006, 07:28 PM #7Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
The engine may need to be mounted higher on the transom. Was the Johnson the same shaft length as the new motor?
09-15-2006, 09:22 PM #8
Does the Etec have any rpm restricting time when new? Seems to me the ecu could be keeping the rpms lower.
09-16-2006, 02:38 PM #9New Member
- Aug 2006
I Was The Same Hight-20" Shaft.the Dealer Raised It Up One Hole And Put On 13 1/2 X15 Pitch Prop S.s.help A Little Gained 1.5 Mph.
Dont Know Where To Go Next-i Think I Got To Call Evenrude
Not Very Happy-pete
09-16-2006, 02:50 PM #105000 RPM
- Jan 2002
- Western NY
- 315
Rigging
My guess is the problem is with the rigging. However, there maybe other issues with it. Where are you located? We work on many E-Tecs, have seen most everything wierd they can do. Working on an E-Tec without a laptop is pointless, if the dealer you're dealing with can't "talk" to the motor, they are wasting your time/money. There are too many dealers out there trying to work on these motors.
