Page 1 of 11 1 2 3 4 5 6 7 8 9 10 11 LastLast
Results 1 to 15 of 164
    Apr 2006
    Roanoke VA.
    My first jet CVX 20 Project boat asnd I have questions
    Ok what do I do next. I have never had a jet before but I have one now! The boat was used in salt water and was last registered in 1994. The seller knows nothing about the boat or it's past. The boat was on the property when he took over a marine electronics business in NC. The boat has no engine and needs a total restoration of the stringers and floor. My question is about the Berkley pump. How do I check it and who do I take it to after pulling it. Can I go through it myself?
    86 Checkmate Enticer 6' jack plate hyd-steering 2.0 merc cowl vents low water scoops laser II floor stringers vinyl gauges and wiring all new (BOAT IS SOLD) 78 CVX20 Jet Project in the works BBC conversion. SML SUPERJETS
    You need "special" tools to take the pump apart without risk of damage. I recommend that you get professional help. The closest I know of is Ted Kempisty at CBM "Custom Berkeley Marine" 1-877-JET-PUMP He is in Syracuse NY. Ted is a very nice fellow and will help with advice and/or service. He has an excellent reputation.
    There are many companies that do Berkley service, however most are west of the Mississippi. Way west.
    Apr 2006
    Roanoke VA.
    Old Sleek
    Quote Originally Posted by OldSleekOlds
    Thank you for the information! Nice Sleekcraft, they are cool boats with a lot history with Bruce Nescher. We just pulled a 18' kauai out of the woods this summer. It is an out-board Kauai, I think it may be kind of rare? My boss has it now but I don't know when he will ever start on it. Thanks Fred!!
    Jul 2005
    High Rock Lake North Carolina
    berkeley
    You can order a kit from Big A performance that has everything you need. The only special tools you might need is a puller for the impellor. I made my own, its simple to make. A basic pump refresh is not very hard. If you want to set your pump up for best performance being a machinist helps. I machined all my own stuff. Big A offers anything you caint do.
    Nitrousdog
    Injection is nice, but I'd rather be BLOWN!
    19' Picklefork w Blown 482, 800hp
    23' Stingray w 550hp 509
    21' Sleekcraft sb 400
    24' Pontoon w killer jam system
    1968 Winns Flat Bottom
    Apr 2006
    Roanoke VA.
    Thumbs up Pump Rebuild Kite From Big A
    Quote Originally Posted by nitrousdog
    Nitrousdog
    Thanks for the information Nitro.. I do work with tools for a living so I think I can figure it out if I take my time.
    Apr 2006
    Roanoke VA.
    Next question
    Any good advice on this mess. Do I just tear it all out and stasrt from scratch or do I try and save what I can. If I pull it all out do I need to reinforce the hull on the trailer some how or will it hold it's shape ok. What material do you suggest I use for the main stringers and what thickness of cloth or mat do you suggest. Thanks Fred!
    Apr 2006
    Roanoke VA.
    Wet floor pic 2
    Apr 2006
    Roanoke VA.
    Got the cvx 20 stripped and dry. Pulling the pump on wednsday.
    Apr 2006
    Roanoke VA.
    First day working on the E-Bay salvage Jet. Removing rotted wood is next
    Apr 2006
    Roanoke VA.
    Pulling the pump not so easy
    OK what is the trick on pulling a pump that has not moved in 28 years. All the bolts are out of the pump and the grate is out. It must be sealer and age holding it in now. The ride plate still has 2 flush mounted bolts in the front of it. It looks like they only hold the forward part of the ride plate to the pump not the pump to the boat. I placed a big block of timber under the ride plate and started cranking slow up on the trailer jack. Rather than lever the pump free it just lifted the rear of the hull off the trailer, Hummmmmmmmm any suggestions. The next thing I am going to try is a heat gun to soften the 28 year old sealer. Fred
    Apr 2006
    Roanoke VA.
    Removing the pump is easy..............................NOT
    It took two of us from 9:00 am to 4:00 pm to get the darn pump out of the boat. I hope it goes back in faster than it came out. Well it's out and no damage was done to the boat.
  12. #12
    Sep 2006
    Glastron support sites
    86Enticer
    You can try this site for additional, Glastron specific help.
    http://groups.msn.com/GlastronCarlso...sageboard.msnw
    Check out the photo section and the forums for info on flooring etc.
    There is also a resource link that had a reference to a boat restoration book that I got off ebay. Lots of good info on replacing floors and stringers etc.
    Good luck, I have the same boat, in the same condition! '76 Glastron Carlson CVX20. I love it, it's so retro and good looking!
    Big D.
  13. #13
    Apr 2006
    Roanoke VA.
    Thumbs up Thanks for the information Big D
  14. #14
    Apr 2006
    Roanoke VA.
    cvx20 repair
    Ok so the pump is out so now the wet and rotted wood needs to come out. Man this thing was built like a tank! I spent the entire day removing wet wood. I filled my truck bed up with the old crap and I only got about 1/2 the of the bad wood out. Looks tike the transom will need alot of work but I need to remove the rest of the foam to see the entire thing. Looks like I one day of stripping left then I can start prepping.
  15. #15
    Sitka, Alaska
    Glass up the hole and add an outboard. That's what my dad did and was much happier (and faster). This is his '73 CV-20 W/ a 225 Yamaha
    Ron Pratt
    '91 Virage "The LAST Virage" 15" 280
    26' Grady White "fish getter"
