Results 16 to 30 of 38
Thread: Painting MADEFI MIDS????
09-21-2006, 08:01 AM #16
Plastic
Confused about the plastic statement. Don't understand about plastic on a midsection. All tech specs I've read powdercoat isn't plastic. Maybe I'm missing something.
1997 Allison XB2003
1998 ProMax 150 SS
09-21-2006, 11:59 AM #17
If you read carefully..................................
Originally Posted by MODXR6Last edited by Fast Fig; 09-21-2006 at 12:07 PM.
09-21-2006, 12:15 PM #18
Powdercoat is plastic powder that's "melted" together to form the coating... there are epoxy, polyurethane, polyester and probably other types of plastics used.
There are fillers that work under powdercoat... Hi-Temp LabMetal is the one that we use:
http://www.eastwoodco.com/jump.jsp?i...emType=PRODUCT
09-21-2006, 01:25 PM #19
powder coating is a bonding to the surface.
Also 1000 times stronger than paint, if done correctly, and metal is clean and prepped you can hit power coat with a hammer, you will dent it, but not chip it.
The only way to remove correctly applied powder coat is to sandblast it.
Also if you do damage an area than has been powder coated, it will not chip further like paint. It is bonded to the surface.
AL“The bitterness of poor quality & service remains long after the sweetness of low price is forgotten”
09-21-2006, 02:01 PM #20Originally Posted by The Big Al
The different types of power have different properties... some are not UV resistant and won't hold up outdoors very well at all. Others are harder but more brittle... and some can be used in greater thickness than others.
You can find lots of info here:
http://www.caswellplating.com/powder/tgic.html
http://www.caswellplating.com/powder/poly.html
http://www.caswellplating.com/powder/epoxy.html
http://www.caswellplating.com/powder/hybrid.html
The high temperature stuff is relatively new, I believe.
09-21-2006, 08:01 PM #215000 RPM
- Nov 2003
- Auckland NZ
- 663
It seems like a 50/50 call, I think in the end I will paint it, reason being is none of the manufactures powdercoat them OEM and I would imagine that would be cheaper for them, there must be a reason why they don't.
Talking of the high temp coatings I have just had the MADEFI tuners done in high temp ceramachrome to keep the heat in them and try and lower the temp's on the outside of the midsection, wether it's in paint or powdercoat.
10-29-2006, 10:34 AM #225000 RPM
- Dec 2002
- long island new york
- 361
powdercoat offshore mid
bigest mistake i ever did, one runand bubbles and lifting.....never again wit this garbage,go paint.......
10-29-2006, 06:12 PM #23Originally Posted by The Big AlBruster's Mercury solid motor mounts, details here:
http://www.powercatboat.com/Bruster/Bruster.htmlI'm been living in fast forward, now I need to rewind real slow....
10-29-2006, 06:15 PM #24
Mine is powdercoated and looks fine
24 SKATER single 300X Sold
28 SKATER 15" 300's
11-01-2006, 08:17 PM #255000 RPM
- Dec 2002
- 361
sure you mid looks good now, wait till it chips and rolls off like wal paper....let us know how it looks then....
11-01-2006, 08:24 PM #26
Has anyone thought to call Wayne and get his opinion? Has anyone ever seen a mid that has come powercoated from any factory or aftermarket supplier?
Kinda makes you wonder....
Ló fasz racing
Joe Horvath
11-01-2006, 09:28 PM #27Originally Posted by GelcoatJoe24 SKATER single 300X Sold
28 SKATER 15" 300's
11-02-2006, 01:43 PM #28
talking to Wayne
Originally Posted by inspectorlance
This is what i posted on the first page.
Lance2005 TRIAD STV EURO
421 HP OMC 3.3 EFI by STOKER
16" Taylor mid, Merc sporty
11-02-2006, 02:01 PM #29
Damm, I missed it. I'd still go paint. I'll try to get a picture of a friends mid that hey painted using Mercury spray paint, of all things. It looks like it was done in a body shop, and it get used a lot. Cost about 40 bucks.
Ló fasz racing
Joe Horvath
11-02-2006, 02:28 PM #30
We're doing a set and....
We're going to have them alodined before the primer and paint. From my experience, the local powder coat shop coatings don't hold up well to carb cleaner and other solvents like many of the better paints do. Maybe its just the materials these shops use. In any case, alodine them first. Merc does.
