Results 1 to 9 of 9
09-07-2006, 03:43 AM #15000 RPM
- Jan 2005
- levitown
- 696
what is a good compression for a stock 1991 2.5 merc 200hp
what is a good compresion for a stock 1991 2.5 mercury 200 hp ??????
09-07-2006, 04:50 AM #27000 RPM
- May 2003
- SOUTH OF BOSTON
- 2,689
120lbs psi
09-07-2006, 07:03 AM #3Screaming And Flying!
- Springfield,La.
- 6,579
- 17
- 2 Thread(s)
Datz what mine wuz, 120!!!
09-07-2006, 07:04 AM #4
with stock heads i have seen as high as 135. however most of them are in the 120 to 130 range. right around 125 is right on.
LAM MARINE RACING
DOMESTIC DISPUTE QUARTERMASTER
Allison SS-2000
21 LIBERATOR
17 ACTION IN DAVE'S MEMORY
BASS TRACKER TF 1600
REST IN PIECE MY BEST COMPANION KIWI ( I LUV U )
09-07-2006, 11:17 AM #55000 RPM
- Jan 2005
- levitown
- 696
thats what i thought (120- 130) stock wasnt sure because i have 2 -2.0 liters and 1 -2.4 liter and now im looking for a 2.5... the motor im looking at is 100 to 105 comp so i think i will pass on it for 3k(it has cle 4 hole and latum steering and cylinder on motor no helm. if i can get it for 2k ,mabee 2.5k . do you think new rings will bring up the compression ???????? or do i need pistons and a bore ???????????
09-07-2006, 12:01 PM #66000 RPM
- Jan 2005
- florence s.c.
- 1,015
Compression
You would really need to mic. the cylinders to know for sure.
09-07-2006, 12:20 PM #7
You should also check it with a different gauge. I have seen big differences from one gauge to another. If the cylinders are all the same compression it could be just the gauge. Usually if rings fail it will happen on one or two cylinders first. All the cylinders usually don't fail all at the same time. This is just another opinion, like rhickox said, the only way to be 100% sure is to pull a head and inspect.
09-07-2006, 04:45 PM #85000 RPM
- Jan 2005
- levitown
- 696
yes i am bringing my compression gauge tommorow to check the compression . i dont trust anyones tools . and i know my gauge is good i checked a few engine with mine . if this engine is under 110 i will pass
09-09-2006, 06:36 PM #95000 RPM
- Jan 2005
- levitown
- 696
i was right his gauge started at 15 psi and when spun the motor it read 115 120 . i brought my gauge and i got 105 109 psi . i will pass on motor they said that was good . i guess it is good if your going fishing . but it sounds like it has a lot of hours on it and needs at least rings . probably a full pistons and bore and all new bearings . lot of work and money . so i am still looking for a 2.5 liter anyone in long island ny ????????
