Results 1 to 10 of 10
Thread: left hand rotation berkly????
08-27-2006, 12:12 AM #1New Member
- Aug 2006
- md
i just picked up a 72 glastron jet drive. the motor supposedly is a worn out 350. and stickered on the valve covers it says left hand rotation. did i miss a memo somewhere? or did berkley run a reverse pump?
i bought it for parts for a 71 sidewinder i'm restoring,,but is it true?this thing is run backwards?smile as you go under
08-27-2006, 03:39 AM #2
Yes, I don't know if all are. But I had one that was.
“The bitterness of poor quality & service remains long after the sweetness of low price is forgotten”
08-28-2006, 12:02 AM #3Originally Posted by bdhr
Does the "worn out 350" run? Does it run backwards?
I can't imagine any reason to run a jet pump "reversed". I guess if you wanted the engine installed with the flywheel towards the front of the boat, you might want to run the engine "backwards" so that a stock jet pump would work driving it off the front end of the engine.
Engines that run "backwards" are not uncommon in twin engine prop boats.
This deal sounds more than a little "off the wall" to me.
08-28-2006, 10:46 AM #4
???????????? some one stick in a lt hand rot. eng out of a twin eng prop boat???? look up in the intake and ck the impeller???which way DOES it need to turn to pump????????NEVER heard of a LT hand pump!!!!!!!!!!!!!
08-28-2006, 01:01 PM #55000 RPM
- Jun 2003
- Toronto, Canada
- 396
I have a problem believing this myself. Why would anyone want to go to the trouble to do this? Lets think you'd need a lefty bowl and impeller and the motor would either need to be driven from the opposite end as mentioned or have a custom cam and the thrust side of the pistons reversed. All for what reason?
I know Mark Nye made his pump reverse rotation but that was to overcome the wrong output rotation of his turbine which is obviously a little harder to "fix" I don't think he wanted to mess with the gearbox on something spinning 30 000+ rpm :O
He had a bowl and impeller made for him and I assume it wasn't "too" much trouble to reverse the CNC/CAD. I believe Eagle/AT took care of that stuff for him
I wanna see pics!
Cheers
08-28-2006, 01:10 PM #6Originally Posted by OldSleekOlds
It was a Inmar Big Block production engine.
Now when I got my BB Ford Boat, I know it was not left hand.
So my previous post of yes, is wrong. Both of mine were right hand!
Go figure, learn something 26 years later!“The bitterness of poor quality & service remains long after the sweetness of low price is forgotten”
08-28-2006, 06:50 PM #7Junior Member
- Jun 2006
- 16
lefty
on most opposite rotation engines the cam gears and the dist gear is what is backward ,as usual motor still turns the same
08-31-2006, 08:42 AM #8
Bdhr
Check Your P.m. And Let Me Know???????
09-04-2006, 06:38 PM #9Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
Maybe
Someone liked those valve covers.
09-04-2006, 08:00 PM #10New Member
- Aug 2006
- md
perfect left hand drive berkley
thank you all for your input!!!!!!!!and i liked dave s 's response ..as well as the others. i'l post pic's of this project soon. thanks again everybody!!!
toddsmile as you go under
