Results 1 to 12 of 12
08-13-2006, 08:46 AM #1Junior Member
- Jul 2006
- 16
MOD VP Exhaust for OMC, Worth Effort?
1988 70 hp Johnson. Is it worth the effort to port the exhaust. Will this gain anything besides sound on this engine. So far accomplished was by suggestions; engine raised, 2 inch spacer plates. Boat is near perfect in water on pad. Running 44 mph at 54 hundred rpm. I am looking for another prop. Current 20 pitch raker, works well just low r's. Any sugestions on props? PS/Carbs a little rich on bottom end. Have to clear its throat after idling. Thanks for everyone who has responded in the past. Got me hooked now.
08-13-2006, 09:20 AM #26000 RPM
- May 2001
- Summit,N.J./Lake George,N.Y.
- 1,189
What hull/prop and prop shaft hight?I have never seen any gains in sport or recreational outboards with loud exhust and you could loose some bottom end torque.When the propshaft is even with the pad the exhaust is out of the water anyway.Full race boats may be a different story.
Gone*
Glasspar G3*
GW Invader*
Allison SS2000*
Allison XR 2002*
Centurion Barefoot Warrior*
Glastron CSS 16*
1988 Viper/never rigged or wet*
1988 Sanger Barefoot V4
2000 Sea Ray 280SS cruiser
Wooden 16 Adirondack Guide Boat
Lowe fishin boat 6hp OMC
1995 Donzi 22 Classic*
1996 Donzi 22 Classic*
Hydstm VooDoo*
08-14-2006, 06:12 AM #3Junior Member
- Jul 2006
- 16
15 1/5 pro-gator 3. Large gear case, 13 1/2 raker, 22 pitch, repitched to 20 pitch. Hight is 1/4 inch above top water intake hole. Have motor to highest point with set-up. 1" spacer plate with 1" 5 degree angle plate. Had no negative trim before. Running pad correct. Still blows out without a stingray tail coming out of hole.. Max trim produces tail at mid to lower cowling high.
08-14-2006, 05:48 PM #4
90 Laser Special Edition 20' Bass Boat 225
Hydrostream Viper
Numerours Hydrosports
Gambler Center Console
Allison XTB 21
Allison GS 2002
74 Sanger Gull wing Flatty 468 BBC
Cole TR2 482 BBC Alky Injected Drag
08-15-2006, 02:00 PM #5Junior Member
- Jul 2006
- 16
Will do
Thanks, will try with current. Any suggestions on prop?
08-15-2006, 02:38 PM #6
I would try a 19 pitch, you are currently running a 20 at 5400 with a 2.1 ratio large 3 cylinder case small barrel at 43 mph gps, which is reflecting a 15% slip which is kind of high, 10% would be good goal. If you went to a 19 pitch and spun 5600 that would reduce your slip to approximately 9-10% and raise your speed to approximately 46 mph. Just my 02 worth
Hydrostream Viper
Allison XTB 21
Allison GS 2002
08-15-2006, 02:45 PM #7
Here is a 19 pitch you could try for cheap http://bbcboards.zeroforum.com/zerothread?id=125303
Hydrostream Viper
Allison XTB 21
Allison GS 2002
08-15-2006, 06:37 PM #8Junior Member
- Jul 2006
- 16
Had tip on 6 holes at 19/32 size each. 3 down each side. Completed. Prop sounds like a gamble from a red gambler to me.
08-15-2006, 08:14 PM #9Junior Member
- Jul 2006
- 16
snappy!
Definatly made a snappy response on the muffs. Water test next. Props? Anything comprable to lift and etc. in a 3 or four blade. If four blade what changes in pitch, diameter, brand and etc. would any one suggest. Really could use a big hand at this one. Thanks dry3 for the tip. PS 20 pitch raker currently.
08-16-2006, 11:34 AM #10Originally Posted by dry3
Hydrostream Viper
Allison XTB 21
Allison GS 2002
08-16-2006, 01:55 PM #11Junior Member
- Jul 2006
- 16
Are we alone
No other experts it seems. Appreciate all the help. I will look to see what I can find.
08-17-2006, 03:59 PM #12Junior Member
- Jul 2006
- 16
What about diameter verses pitch. Current raker is 13 1/2 diameter. Would this need to stay the same?
