Results 1 to 6 of 6
08-10-2006, 06:44 AM #1
2.4 CARB to 2.5 260 EFI Conversion?
In summary, what does it take? From bolting on to fuel system?
Talon 18
08-10-2006, 06:48 AM #2
two completely different motors. Not sure I understand what you're trying to do?
08-10-2006, 06:50 AM #3
Drop a...
260 EFI where my 2.4 carb currently sits on my boat Does this require a new wire/ignition harness?
Talon 18
08-10-2006, 11:53 AM #4
Anybody?
Just a quick response will do:
Do I need?
1. High pressure fuel pump w/ return line to tank?
2. New wiring harness?
3. New exhaust adapter plate?
What are things to look for as far as ECU #, stock compression #'s, limter setting, etc.Talon 18
08-10-2006, 12:52 PM #5Originally Posted by LikwidCourage
2. NO, the stock control harness is OK. The electrics themselves are completely different.
3. NO, you can use the 200 plate, but the exhaust passages are a bit smaller. Didn't seem to be a problem with mine, it pulls like hell. You must use a BP or 260/280 style cowl, as the lower pan/plate blocks off the poppet dump passages, for motors like this that use NO poppet or thermostats.'89 Hydrostream Vegas XT, '90 Merc 2.4 Bridgeport PCU EFI
08-10-2006, 06:41 PM #6
Thanks Pyro
Everyone must be busy gettin ready for the Rumble...
Just found out I might see ya there...
Comin down with a crazy group of canuksTalon 18
