Results 1 to 15 of 15
Thread: Hot Trailer Tires
08-06-2006, 07:56 PM #1New Member
- Aug 2006
Hot Trailer Tires
I have an 18' Tri-Hull on a single axle trailer. After hauling it today for about 30 miles, I noticed that both tires were quite hot. The hubs and rims were cool. Tires are at proper inflation, and bearings were recently packed with high-temp grease. Am I missing something, or is this normal?
08-06-2006, 09:24 PM #2Screaming And Flying!
- Sep 2003
- shreveport,la
- 5,497
- 18
- 24
- 212
In the height of Summer it doesn't seem abnormal, just how hot are your talking about... Even the tires on My Chevy get pretty warm just driving home from work, not too hot to touch but but maybe uncomfortable for the back of My hand... Have you notice if your tire/axles are aligned correctly..?
Kevin Kiser
08-06-2006, 09:45 PM #3New Member
- Aug 2006
Originally Posted by Ted Stryker
It may well be normal -- I'm pretty new to boating. I can only keep my hand on it for about three seconds. They are bias-ply Carlisles. The axle doesn't seem to be obviously out-of-whack, and the trailer tows nicely.
08-07-2006, 06:02 PM #4Screaming And Flying!
- Sep 2003
- shreveport,la
- 5,497
- 18
- 24
- 212
If you can only touch it for a few seconds, that seems a little excessive... You know that the air pressure is correct, is it possible that the tires are overloaded... I'm sure that you taken that into consideration, but I don't know where else to look... Have the tires been on long enough to notice any kind of wear pattern..?
Kevin Kiser
09-05-2006, 07:30 AM #56000 RPM
- Florida
- 1,881
The correct pressure is 50 psi. Is that what you are running?
jim
09-08-2006, 02:26 AM #6
Usually the only things that would cause a tire to overheat like that (and yes can't touch them for more than 3 seconds is way too hot) would be under-inflated, overloaded, or axle problems. Check tire pressure, load rates, and axle alignment, if all of these things are right I would start looking for new tires cause it sounds like a serious defect in the belts causing excess friction. They aren't Firestone Wilderness A/T i hope
06-01-2007, 07:05 PM #7Junior Member
- Jun 2007
- chesapeake Va.
- 16
i would say under inflated and over loaded
09-16-2007, 01:09 PM #8
What is the approximate weight of the boat and tralier? Like the others said, it may be overloaded. Make sure the tires are inflated to the max pressure indicated on the sidewalls. If you have the correct tires (trailer tires) it should be at least 44 PSI, probably 50 PSI.
Rob
Rob1987 Checkmate Starflite-86mph on GPS, so far...
1988 Fiero GT-Future Track Car
1990 Miata-Daily driver
1997 Viper GTS-Weekend warrior/track toy
1999 Swift 010c- CART racecar
2000 Civic Si- Daily driver
2000 F250- 7.3L PSD 6-speed
12-17-2007, 03:51 PM #9Member
- Jul 2006
- 39
Check the load range on the tires. It's hard to believe but some people put the cheapest s*** they can find on their rigs.
07-28-2008, 12:36 AM #105000 RPM
- Jul 2008
- Port Angeles, WA
- 888
Typically, the maximum that most people can hold their hand in constant contact to is 140F. If you tires are above that, see if you've got too many coolers left in the boat or some other source of extra weight.
05-09-2009, 07:19 AM #11
What size are they? If they are too small, they may be spinning too fast for that load. What I mean is, if the circumference of the trailer tire is half of your car tire...... If you are driving 70 mph, your trailer tire thinks you're driving 140!
Good luck
06-18-2009, 07:35 PM #12Member
- Mar 2005
- Central Florida
- 31
Make sure there not 13 inch tires. you need at least 14 to 15.
06-18-2009, 11:20 PM #13
Good for you Jackofthelake at last someone asked what size tires?
I towed my 18' DUO, a big 18, w/ 150 Merc inline6 from Phila, PA to Newfound Lake NH and back twice behind a 340 Duster long before the 55mph speed limit and may have gone slightly faster than what was posted also from Phila to Ocean City MD also from Philly to Bricktown, NJ many times all during the summer months 4.80 X 8""Where is Lee Harvey Oswald, Now that we really need him?"
06-19-2009, 03:39 PM #14
Since the original poster has not been on here in almost 3 years I don't think the problem bothers him anymore or he went up in flames from the hot tires.
Ralph Musser
27' Fountain Fever W/ 525SC
22' Rapid Craft W/ Evinrude 300 V8 January 2009 BOAT OF THE MONTH SOLD
24' Triton 240 Gold W/ Mercury 60
14' Royalcraft W/ Evinrude 75 father/daughter project
06-20-2009, 02:57 AM #15
Way to go Ralph, ya sure know how to flock up our fun, yeah, ya herd me right!
On the bright side he may check in tommorrow, for lots of expert advice, ya never know."Where is Lee Harvey Oswald, Now that we really need him?"
