Results 1 to 4 of 4
08-05-2006, 12:10 PM #1
2.4 EFI Bridgport Merc Fuel Pressure
does anyone know the correct fuel pressure for the 2.4 bridgeport EFI motor I bought one that had external pump and not sure what to use on it or how to pipe up the return any ideas or links I will be most greatfull
08-05-2006, 02:03 PM #2
39 psi. The regulator is on the motor.
Use 3/8" high pressure fuel hose.
Fuel pump and filters connect to the fuel rail at the bottom (it's a common hardware store thread fitting), connect the return line back to the fuel tank. I did this with mine by taking a thread-together type tire valve stem, removing the valve, drilling it out to 1/4" ID, ground the threads off the stem, and tapped it into the filler neck hose.'89 Hydrostream Vegas XT, '90 Merc 2.4 Bridgeport PCU EFI
08-05-2006, 02:36 PM #3
You will need an extremely high output pump to run that motor. Around 100 GPH. Most EFI pumps will not work on a high performance outboard. They run lean and melt the pistons. Talk to Tony Brucato for a good pump, here is his website.
http://www.brucatosvs.com/
08-05-2006, 10:32 PM #4
2.4 fuel
thanks to all for the info that is what I was wanting to make sure before I ordered somthing I could not use rigging this motor out on a 91 bullet 15" plate hope it does good.
