Results 1 to 7 of 7
07-27-2006, 08:10 AM #1
Preping V-king trailer for long haul
I am going down to school in florida and i WILL be bringing the vking/200johnnyrude with me... I have it on an older trailer anything you suggest i do to prep it for the long haul? I am going to add 2 more bunks (2x6s) along with the 2x4s that are on there.
should i change the bearings? or just grease them?
should i pull the power head? lessen the weight on the back?
thanks
kevin
07-27-2006, 10:27 AM #2Screaming And Flying!
- Oct 2003
- Cobourg, ON
- 7,194
Bearings are cheap. Change 'em. Also buy new tires, you won't regret it.
07-27-2006, 10:29 AM #3
Might wanna get new wheels and tires
That way ya got a couple of spares.
Rickracer
Sunshine Syndicate Member
There is a fine line between "hobby" and "mental illness."
[img]http:/
07-27-2006, 01:39 PM #4
07-27-2006, 02:36 PM #5
Only thing I might think about besides tires and bearings is removing the lower......Only because of the chance of it disapearing ( stolen) whne you lay over if you have a sfe place to store it and are doing a non stop like I do then RUN IT!!!!!!!!!
Jeff
ps check your springs and hangers also!! a quick spray lube on the won't hurt....Keep in mind also if you use it in the salt water RUST!!!! so depending on the shape of it you may want to give it a squirt of paint to make it last a bit longer...or think about upgrading to Aluminum once your there you can shop them pretty cheap in Fla....
07-27-2006, 02:56 PM #6
07-27-2006, 03:15 PM #7
add a transom support from the trailer to the lower unit it will take the stress off the transom for the ride..... there cheap insurance. at least the galvy will last longer than an old steel trailer in the salt water
