Results 1 to 9 of 9
    May 2005
    Branson, Mo
    gelcoat overspray removal
    Had some gelcoat work done and now my merc alien engine covers are covered in white gelcoat overspray. How do I remove it from plastic?
    Thanks
    Branson, Mo
    Current boat
    Excalibur?Riviera 45
    28 Pantera Race Outboards
    Jan 2006
    MIA.
    Sorry to hear that!!! I know how unpleasant that can be, the particles are usally thicker than if they were paint. The good news is, usually you can overcome the problem by buffing it out. I recommend you mask off your decals as if you were going to paint so you won't eat up the color, use a fine grade compound with a wool pad & DO NOT press down very hard or keep the buffer over the same area for long periods of time cause you could burn the plastic, so buff lightly till overspray is gone then switch over to foam pad & use finnessit by 3M to glaze & remove swirl marks. Good luck you should have no problems ( DO NOT USE ANY TYPE SOLVENTS ) Peace! FIG
    Nov 2004
    BAYVILLE N.J.
    get detailing clay
    go to an autobody or a good auto store,mguires makes it here is the link
    http://www.meguiars.com/?auto-detail...rface-Clay-Kit
    trust me it works
    May 2005
    Branson, Mo
    Thanks guys. I ended up buying a clay bar a couple of weeks ago. Worked great. I was impressed how well it worked. I will have to find some other uses now.
    Branson, Mo
    Current boat
    Aug 2006
    Talking
    I would have taken it back and let whoever did it take it off.I've been painting for over 25 years and belive me if I miss somthing , I'll be the one who makes it right
  6. Likes NICE PAIR liked this post
    May 2005
    Branson, Mo
    Most of the time I would have to. To the shops defense, Work was great, 2/3s less money than all other quotes, and I had to have it by the weekend so I said I would finish it.
    Branson, Mo
    Current boat
    Aug 2006
    bahamatrama - Your my kind of boater,I don't mind lowering prices for boater's with that attitude
  9. #8
    Aug 2006
    Kernersville, NC
    Not sure where exactly or how bad the overspray is but if the cover is in good shape (glossy) then a clay bar should take it off pretty easy. Less effort than cutting down with a buffer and no risk of burning the cowl.
  10. Thanks Shamir thanked for this post
    Mar 2024
    VA
    Thumbs up
    Indulge in perfection with Pentagon Detailing's premier service! Our Platinum Auto Detailing includes top-tier treatments like the Clay Bar Treatment and 9-Step Paint Solution. Pamper your vehicle with the luxury it craves. Explore our offerings at https://pentagondetailing.com/.
