Results 1 to 15 of 15
    Aug 2004
    Venice, Florida
    Need a plate made to raise motor 3" with minimal setback.
    I need to raise my motor (already on top mounts) another 3" or so without adding any more setback then possible. I have been told I can have a 3/4" aluminum plate made to extend the height. Any suggestions appreciated.
    Kissimmee, Florida
    A relatively simple and cost effective solution is.....
    ....a Bob's Machine 4-in-1 convertible MJ-5 jackplate. They can be assembled with only 2.5" of setback, and 6° of negative wedge or no wedge. Another simple and cost effective solution would be a CMC 50012 5" vertical extension. It is designed to add 5" of engine height with very little setback. By shuffling which motor bolt holes you use, that could be 3~3.5" of added height.
    Rickracer
    Sunshine Syndicate Member
    There is a fine line between "hobby" and "mental illness."
    [img]http:/
    Aug 2004
    Venice, Florida
    I was looking at both of those on your site as a matter fact. If I call, who should I ask for since you already know what I'm trying to accomplish?
    Nov 2004
    LEBANON OREGON
    either barb or rick will know that answer..
    Oct 2003
    HICKORY, NC
    Cook Manufaturing, CMC
    <TABLE cellSpacing=0 cellPadding=7 width=549 border=0><TBODY><TR><TD vAlign=top width="52%">
    </TD><TD vAlign=top width="48%">
    The 5 inch vertical extension allows the motor to be mounted 5 inches higher than the standard mounting on the transom. It is a must for conversion from a prop to jet drive. Another application includes mounting the 5" vertical extension on the hydraulic Power-Lift to raise the motor higher on shallow running boats that are equipped with tunnel extensions.
    </TD></TR></TBODY></TABLE>Web site, http://www.cook-mfg.com/
    Now one trick is to take a 5 or 6 jack plate that has outside the rail adjustments, (ie: Springfield) and invert the engine mount plate.
    Al
    “The bitterness of poor quality & service remains long after the sweetness of low price is forgotten”
    Oct 2003
    HICKORY, NC
    JAck plate companys
    <TABLE cellPadding=2 width=560 border=0><TBODY><TR><TD width=206 bgColor=#008080>Jackplates</TD><TD align=middle width=135 bgColor=#008080>Phone</TD><TD width=277 bgColor=#008080>Location</TD></TR><TR><TD width=206 bgColor=#c0c0c0>Bob's Machine</TD><TD align=middle width=135 bgColor=#c0c0c0>(800) 966-3493</TD><TD width=277 bgColor=#c0c0c0></TD></TR><TR><TD width=206 bgColor=#c0c0c0>CMC</TD><TD align=middle width=135 bgColor=#c0c0c0>(800) 654-3697</TD><TD width=277 bgColor=#c0c0c0></TD></TR><TR><TD width=206 bgColor=#c0c0c0>Danaco Inc</TD><TD align=middle width=135 bgColor=#c0c0c0>(337) 989-2123</TD><TD width=277 bgColor=#c0c0c0></TD></TR><TR><TD width=206 bgColor=#c0c0c0>Detwiler</TD><TD align=middle width=135 bgColor=#c0c0c0>(888) 853-4484</TD><TD width=277 bgColor=#c0c0c0>Elverson, PA</TD></TR><TR><TD width=206 bgColor=#c0c0c0>Hydro-Dynamics</TD><TD align=middle width=135 bgColor=#c0c0c0>(318) 965-0201</TD><TD width=277 bgColor=#c0c0c0></TD></TR><TR><TD width=206 bgColor=#c0c0c0>Hydro Tec</TD><TD align=middle width=135 bgColor=#c0c0c0>(417) 725-5746</TD><TD width=277 bgColor=#c0c0c0></TD></TR><TR><TD width=206 bgColor=#c0c0c0>J & B Industries</TD><TD align=middle width=135 bgColor=#c0c0c0>(800) 382-6457</TD><TD width=277 bgColor=#c0c0c0></TD></TR><TR><TD width=206 bgColor=#c0c0c0>Land & Sea</TD><TD align=middle width=135 bgColor=#c0c0c0>(603) 329-5645</TD><TD width=277 bgColor=#c0c0c0></TD></TR><TR><TD width=206 bgColor=#c0c0c0>Mercury Precision Prod.</TD><TD align=middle width=135 bgColor=#c0c0c0>(800) 637-2879</TD><TD width=277 bgColor=#c0c0c0></TD></TR><TR><TD width=206 bgColor=#c0c0c0>Panther Marine Products</TD><TD align=middle width=135 bgColor=#c0c0c0>(612) 934-7000</TD><TD width=277 bgColor=#c0c0c0></TD></TR><TR><TD width=206 bgColor=#c0c0c0>Port City Propeller</TD><TD align=middle width=135 bgColor=#c0c0c0>(888) 660-4152</TD><TD width=277 bgColor=#c0c0c0></TD></TR><TR><TD width=206 bgColor=#c0c0c0>Porta Products</TD><TD align=middle width=135 bgColor=#c0c0c0>(904) 428-7417</TD><TD width=277 bgColor=#c0c0c0></TD></TR><TR><TD width=206 bgColor=#c0c0c0>Rite-Hite</TD><TD align=middle width=135 bgColor=#c0c0c0>(417) 442-3277</TD><TD width=277 bgColor=#c0c0c0></TD></TR><TR><TD width=206 bgColor=#c0c0c0>R & R Design</TD><TD align=middle width=135 bgColor=#c0c0c0>(972) 563-1789</TD><TD width=277 bgColor=#c0c0c0></TD></TR><TR><TD width=206 bgColor=#c0c0c0>Springfield Marine </TD><TD align=middle width=135 bgColor=#c0c0c0>(417) 725-2667</TD><TD width=277 bgColor=#c0c0c0></TD></TR><TR><TD width=206 bgColor=#c0c0c0>Stainless Marine</TD><TD align=middle width=135 bgColor=#c0c0c0>(305) 681-7893</TD><TD width=277 bgColor=#c0c0c0></TD></TR><TR><TD width=206 bgColor=#c0c0c0>T-H Marine</TD><TD align=middle width=135 bgColor=#c0c0c0>(256) 772-0164</TD><TD width=277 bgColor=#c0c0c0></TD></TR><TR><TD width=206 bgColor=#c0c0c0>T & R Marine</TD><TD align=middle width=135 bgColor=#c0c0c0>(850) 584-4261</TD><TD width=277 bgColor=#c0c0c0></TD></TR><TR><TD width=206 bgColor=#c0c0c0>Vance Mfg</TD><TD align=middle width=135 bgColor=#c0c0c0>(931) 425-6820</TD><TD width=277 bgColor=#c0c0c0></TD></TR></TBODY></TABLE>
    underlined, click for website
    Jul 2002
    Las Vegas, NV
    Hey Mr. Demeanor...I need the same thing. I've never run across one, so I'll likely have to build my own, but I'm thinking a 5/8" - 3/4" thick alum plate, drilled with several positions in 1" increments.
    I need to raise my motors, but I'm not sure how much, and I want to figure that out before getting jackplates, so I know what my operating range is.
    Keith-
    Jul 2002
    Las Vegas, NV
    OK, I guess this was the excuse I needed to get the plate designed up. Mr. Demeanor, are you running a Merc or OMC? I've got the plates designed...I will send the drawings over to my machinist on Monday. Pretty simple, but material is spendy these days.
    PM me if you are interested in one or more plates.
    Apr 2006
    Great East Lake, Acton, Maine
    hoist the engine off and stick a 2x3 between the engine and transom. center the engine on tbe boat,seal the old holes, and drill for new engine bolts. did the same thing on my searaider with a 50 merc, but i lifted it 1". got 2-3 mph!
    and you get no setback, whatsoever
    1984 Nordic pickel fork. 2.5L 245 carb, CLE. top speed: 95mph with more to go
    Jul 2002
    Las Vegas, NV
    Kinda hard to do when the motors are on brackets Juggernaut.
    Apr 2006
    hmm.. you make a very convincing point . well, it worked on my smaller engine. i got the engine with the T-handles on the transom. 1980's 50 horse
  12. #12
    Jul 2002
    Las Vegas, NV
    Got mine done. Built out of 3/4" T-6061 aluminum plate.
  13. Thanks John Rork thanked for this post
    Likes John Rork, rgsauger liked this post
  14. #13
    Nov 2004
    LEBANON OREGON
    that MAY be heavy enough...... just dont go doing super mondo huge air with it..
  15. #14
    Jul 2002
    Las Vegas, NV
    No air man...it's on a 30 footer! These are just going to be used to let me move the gearcases up to get an idea of where they want to run. The end result will be a new Stainless Marine bracket with jack plates, knowing where they like to be.
  16. #15
    Nov 2004
    LEBANON OREGON
    Quote Originally Posted by STV_Keith
    LOL.. I have seen a 30 scarab out of the water... off a 4 ft tugboat wave... but it wasnt very far out.. just warnin ya those v8's can break anything given half a chance..
