Results 1 to 5 of 5
05-24-2006, 09:12 PM #1Member
- Jan 2006
- Pigeon Lake, Ontario, Canada
- 42
Mirage, vs. Mirage Plus, Interesting tests....
Hello all,
Just curious if anybody has some feedback on my test results tonight.
I have a 23" Mirage old style, cupped to 100,000, that ran 67.2 MPH but over-revving a 454 Magnum @ 5200-5300 RPM. Good hole shot, good prop, just a bit to high in revs, and would like just a bit more speed. This prop, when worked, had the polish finish taken off, supposedly would bite bitter with the non-polish finish.
So, i tried a 25" Mirage Plus, first generation without the PVS system, but a Mirage Plus, non the less, (polished finish). It ran 64.2 MPH, with the same weight of gas, and only revving 4550 RPM. It is only 1 size difference. Are the Mirage, and Mirage Plus, really that different ? that's basically 700 RPM and really more then that because i had the 23' cupped so it would bring the RPM's down abit.
Any feedback, would be appreciated. The boat is a 23' Phazar with a 454 Magnum, and a Bravo 1 drive with nose cone.
Thanks everyone,
Shawn
05-26-2006, 11:40 PM #2
- Dec 2002
- Algonac Mi. On the North Channel "were it all BEGAN"Prosperity, SC on Lake Murray in the Middle of Holiday Acres !& Bossier City La. Not far from a ramp !
- 1,041
Shawn, Call Hydromotive (330) 425-4266 tell them your spec's they will steer you in the right direction.
SparkGoing back to my Old Man's Moto's
" Keep It Small and Keep It ALL $$ "
" Throw enough CRAP at the WALL sooner
or later something will STICK ! "
Vicious Race Boats
(803) 944-3596
06-09-2006, 06:31 PM #3
25" Mirage Vs Plus 25"
Cptn, In My Exp Yes!!!
Big Diff Between Those Props The Plus Is Gonna Need More Hp
To Turn The Same Rpm !!!
But In Return Net More Top End !!
I Have Owned Both Blades As Well As A Hydromotive 3 Blade 24"
And Run Them On A 240 Sport Baja Bravo W/ Hydromotive Nose Cone.
Will Sell Any Or All Of My Used Hdw.
Call 815-334-1103 Craig.
06-10-2006, 09:09 PM #4Junior Member
- Jun 2006
I did a 1 to 1 comparison with my 32 Sunsation and the Mirage Plus were .8 mph faster, so I stuck with the old Mirages.
06-11-2006, 10:42 AM #5
If you are talking about the BARRETTA Phaser, (23 foot), I had one with a 350 that would only run about 60 MPH , (no GPS then).
My buddy bought it from me and put a 454 w/ just under 500 HP in it.
79.6 GPS with a 28 Hydromotive.
It looked like a totally different boat at those speeds, looked like the Hydrostream way up on the pad, almost no boat in the water.JOHN MASON
'83/VECTOR/MERC 200-- SOLD
'98 Quartershot T-3/ MERC 200
"If your not living on the edge, your taking up to much space"
