Results 1 to 15 of 27
Thread: Lapping reeds?
05-22-2006, 03:02 PM #15000 RPM
- Feb 2002
- 120
Lapping reeds?
I thought I better start a new thread so I get get an answer a little faster. I'm about to start putting in these reeds. In an earlier thread I got some information on how to lap the reed blocks. Since I am not sure what this accomplishes, how do I know when I am finished or when they are properly lapped? The new reeds are going into a 1981 175 horse Johnson.
05-22-2006, 03:12 PM #2
a little rough
What you're doin' is making the cages straight. From the factory... they're
a little rough, and the reeds will rest a little open. This is where a small
amount of hp is lost. On a lake eng... you probably won't notice any change.
05-22-2006, 03:32 PM #3
Emery Cloth
Emery cloth and a nice flat piece of glass. You're simply making sure they seal. When your surface if flat the sand marks will be uniform.
05-22-2006, 06:49 PM #4
I did mine on the kitchen glass top table when the girlfriend was at work. I used 220 and wet sanded it untill the whole surface was smooth and perfectly flat.
------------'82 Vector - Mercury 2.4 Bridgeport "MOD"
"Life is short - Get there fast...MERCURY"
05-22-2006, 07:09 PM #55000 RPM
- Feb 2003
- Living on the far right
- 686
What about rubber coated reed blocks(Yamaha)?
05-22-2006, 10:28 PM #65000 RPM
- Dec 2005
- Valrico Fl.
- 564
I sanded my rubber Yamaha cadges using wet and dry 400 sand paper and a flat stone. I would install the new reeds hold them up to a light than work on the area that was high and keeping the reed from sitting flat and sealing. It takes a few mins. but its the little things that give you a edge.
05-23-2006, 11:25 AM #7Originally Posted by vector mike
05-23-2006, 12:23 PM #8
That's me...
I resemble that remark. I've always been involved in something fast and doing whatever it takes to get it done. If the girlfriend only knew half the stuff I'v e done we probably wouldn't be together. That's why I love working different shifts than her.
05-23-2006, 09:10 PM #95000 RPM
- Feb 2005
- 319
You need to lap them in a figure 8 motion on flat glass till you can see a even cut.
12-07-2014, 06:16 PM #10
Would there be any benifit to lapping the sealing surface area a slightly diffrent angle than the reed mounting area? To make them press on the sealing area a bit harder? Or sand the whole reed block flat and even all together?
12-07-2014, 08:49 PM #11
Start out getting them flat. Playing with 2 angles will get real involved fast because what its going to want will be dished. Controlling the dish, hmmmmm, I don't even want to try without a grinder. Now, you can try shimming under the reed to get the same effect.
12-07-2014, 09:18 PM #12
A magic marker scribbed all over makes seeing when your done easy. Poor mans dye chem.
I used the top of my table saw and found some stick backed sandpaper at home depot.13' Biel tunnel AKA "Flight Risk"
21' Paramount
Mercury 300 Promax
12-07-2014, 09:37 PM #13
Black marker sounds like a good idea. I'll do that and open up the blocks a bit.
12-07-2014, 09:57 PM #145000 RPM
- May 2007
- STL
- 856
- 14
- 15
- 48
- 25
12-07-2014, 10:16 PM #15
I have a set of lapped cages done by Chris Carson on my looper. If you want to be sure they're right, send him yours.
