Results 1 to 9 of 9
05-04-2006, 11:19 AM #1
Bridgeport combustion chamber size
Which motor(EFI or carb)or year did the 26cc chamber head come on on the Bridgeports? Did all the BP's come with 26cc heads? I know their port height is higher so did they put the small chambers on all of the BP's to keep the compression up?
------------'82 Vector - Mercury 2.4 Bridgeport "MOD"
"Life is short - Get there fast...MERCURY"
05-05-2006, 09:55 AM #2
I know there must be at least 1 of you motor guru's out there that know the answer to this.
05-06-2006, 08:06 PM #3
My 91 BP had 37cc chambers stock.
05-06-2006, 08:40 PM #4
26's???
Sounds very tight for a stocker. Never heard of one that small stock. Maybe 36cc's. I know they are slightly smaller than the 260's and those were generally 42 or 37cc.
26cc would be stock on a 300 drag. It would require substantial octane on a BP or a 2.5 . Most people run 100 octane with 26's but you could probably run 97-98 or so comfortably on a 2.4.
05-07-2006, 07:06 PM #5
I bought a new MOD-VP carb BP in 1986 and it had 2-piece heads that had .80 stamped on the top of each head. I'm not sure what that would mean as far as CC's, but I know Mercury said to run 100LL Avgas. That motor had great midrange power.
05-08-2006, 01:07 AM #6
bridgeport
2.4 bridgeport mod vp was 26cc, they used 2.0 litre heads cut .080"
Popey
05-08-2006, 07:36 AM #7Originally Posted by Steve Pope
Aah, good catch. The Mod VP requires over 100+ octane, the EFI and OS get by on 90, now I know why.
05-08-2006, 08:14 AM #8
Thanks Steve
I knew somebody here would know.
05-08-2006, 02:32 PM #9Banned
- May 2001
- Lake Keowee, South Carolina
- 1,041
And contrary to popular belief, the MOD-VP carb engines put out more horsepower than the EFI engines. They were around 265 crankshaft HP, but I see posts here, all the time listing the EFI with more. This is for from the factory engines, not the ones modified by someone after leaving Mercury.
