Results 46 to 60 of 69
Thread: New member first post
05-11-2006, 08:59 PM #46
Pic of the cap
86 Checkmate Enticer 6' jack plate hyd-steering 2.0 merc cowl vents low water scoops laser II floor stringers vinyl gauges and wiring all new (BOAT IS SOLD) 78 CVX20 Jet Project in the works BBC conversion. SML SUPERJETS
05-11-2006, 09:08 PM #47
Skeekcraft decal
05-11-2006, 09:31 PM #48
Looks like one hell of a project , good luck with it. Keep us posted as you go , it will be nice to see it get finished.
OneBigAssMistakeAmerica
"No good deed goes unpunished"
81 Sanger Alleycat
1984 21' Carrazza w/mariner magnum 2.5 200 EFI
www.rinaldi-engines.com
05-12-2006, 06:45 AM #49
That's one bada$$ looking back of the Camaro in the background. Looks like a drag car. I see the 1 slick sitting there behind the boat top.
------------'82 Vector - Mercury 2.4 Bridgeport "MOD"
"Life is short - Get there fast...MERCURY"
05-12-2006, 10:21 PM #50
Mike it's a outlaw street car being de-tuned for thr street
Originally Posted by vector mike86 Checkmate Enticer 6' jack plate hyd-steering 2.0 merc cowl vents low water scoops laser II floor stringers vinyl gauges and wiring all new (BOAT IS SOLD) 78 CVX20 Jet Project in the works BBC conversion. SML SUPERJETS
05-14-2006, 06:02 PM #51
Back to my Enticer set up
Ok the second prop I tested was a Hustler 14.25 X 21. That prop did not hook up on the hole shot it wanted to blow out on take off, I lost 3 to 4 mph and the RPM's went up from 5100 or 5200 with the 13.75 X 23 Laser II to 5600 to 5700 with the Hustler. The boat acted crazy in turns. It wanted to rock from side to side really bad but did this only when turning. Why did that happen? It didn't feel like my usual 57 to 60 MPH chine walk. This was a rocking sensation from side to side. I do have two other props to try. The first is a 14 X 21 Trophy plus 4 blade. I hope this will be the one that works best. I want a better take off, solid turning, and 60 mph with no chine walk. I hope the 4th blade will make this prop turn RPM's like a 14 x 22 3 blade. The second prop is a 14 x 22 Tempest 3 blade. I will get to test run next on wednsday the 17th. I will let yall know how that worked out. Thanks Fred
05-17-2006, 05:57 PM #52
I've been following your conversations. A lot of good info.
I think you will like the 4 blade for what you are trying to accomplish.
From my experience (21' Starflight), the 4 blade is the best compromise for speed and handling as well as hole shot on these older heavier hulls.
I think you will notice a big improvement.
Another benefit is the 4 blade tends to help with transome lift. You want to lift the boat out of the water while still keeping a fairly level posture. Over trimming and an overly high bow with that hull will not only slow you down but make the boat handle poorly.
Hope thats helpfull.
05-17-2006, 08:18 PM #53
Show Time
Hi Show Time, I ran the Trophy Plus today and wow what a killer hole shot! That thing don't play around on take off. The 14x21 Trophy runs the same RPM as my 13.75x23 Laser at WOT but the Trophy runs 5 mph slower ?? The Trophy made the boat feel like it was slipping all around on ice ?? I remover the plugs from the Laser, went up 1/2" on the jack plate then retestd. This helped the the hole shot big time. Still boggs down some but not 1/2 as long as it did before. The water pressure was still good at 18 pounds at WOT and I picked up one mile per hour. After testing 3 props I think the Laser II is the one I will stick with. I want to thank every one for the comments and suggestions it was a big help to this rookie. Thanks Fred!
05-18-2006, 09:54 AM #54
Hey Fred,
Sounds like what you are feeling with the Trophy is the boat finally getting some lift. You may benefit from some further testing of your engine hight prop pitch and trim angles.
Good Luck."Show Time"
21' Checkmate Starflight 1986
05-19-2006, 09:56 PM #55
Keep going up on the jack plate
Originally Posted by Show Time86 Checkmate Enticer 6' jack plate hyd-steering 2.0 merc cowl vents low water scoops laser II floor stringers vinyl gauges and wiring all new (BOAT IS SOLD) 78 CVX20 Jet Project in the works BBC conversion. SML SUPERJETS
05-20-2006, 10:10 AM #56Junior Member
- Apr 2006
- 28
Just my 2 cents worth. If I was only getting 5200 rpm with that laser I would get a smaller pitch. Try the 21 laser and let the motor hit 5600. You will find the hole shot much better and you may even find an increase in top speed. I had a 21 pitch on my sea ray with that same motor and I found it ran much better with the 19 pitch laser.
05-21-2006, 02:37 AM #57
21 22 or 23 pitch
Originally Posted by Spudly86 Checkmate Enticer 6' jack plate hyd-steering 2.0 merc cowl vents low water scoops laser II floor stringers vinyl gauges and wiring all new (BOAT IS SOLD) 78 CVX20 Jet Project in the works BBC conversion. SML SUPERJETS
05-26-2006, 01:01 AM #58
Feels like 60
05-26-2006, 09:58 PM #59
Nice shot. it looks pretty stable there. did you work out the chine?
05-27-2006, 04:57 AM #60
Hi Boston
It seems like the higher I go up with the jack plate the better the chine walk is. I just went up another 1/2" but have not ran it at that hight. I think it's up about as far as I can go. The bottom of the scoops are almost totally of the water now. Don't know if the water pressure is still going to be good but I will find out monday. If not back down 1/4" retest and that will be about it for this set up. Looks like I will need to install a nose cone kit if I want to go up higher. I'm ready to see your new boat on the water. It Looks fantastic, I think you are going to like the extra room. Thanks Fred!
