Results 1 to 7 of 7
Thread: Set-up For Glastron Gt-160
03-25-2006, 02:44 PM #1New Member
- Oct 2004
- champaign, il
hey guys, i have a 76 glastron gt-160 with a johnson 115 V-4 and was wondering if anyone had some tips for alot of speed. I have a 4 inch jackplate that i was planning on putting on it and a custom made gas tank that is in the front of the boat (12-15 gallons). any info would help! p.s. this is my first boat
03-25-2006, 04:13 PM #2
Does it also have an aft gas tank?
Jeff Bare
Gig Harbor, WA
03-26-2006, 10:36 AM #3
nope just front tank now just going to be a battery in back
03-26-2006, 02:37 PM #4
Depends How Fast Ya Want Ta GO~!
Hey There: Depends how fasy ya want ta go. Your should do about 40-44 MPH with the 115. I've got a 78 GT-150 90 Merc & it did 42 at best. I was thinking doing the same but then just went out & bought a 84 Hydrstream Valaro 2.4 Bridgeport which is designed for high speeds. The GTs are designed for under 50 MPH so you would need to do extensive mods for a bigger motor. Check out this site as It shows the Mods ya need to do. www.Carlsonspeed.com . I went though these thoughts with mine & decided to leave it as is & go the Valaro way.
Good Luck
Kelly B
04-14-2006, 10:02 PM #5
about 2 years ago i bought a carlson gt 160. it had a merc 115 tower of power, n trimmed, i was seein 56mph @wot. what exactly are you willing to do for more speed?just simple things, or would you consider havin the heads shaved, exhaust ports bored, etc..
04-15-2006, 06:44 AM #6
Hi,
I had a while ago ( 15 yrs) a GT-150 set-uped with a 140 OMC stock, a chopper OMC and i was rinning in the upper 60's with a lot of chine walking. I moved up to a OMC 235 V6 and went up to lower 70's with more chine walking but after experience, i was able to manage it ( even though it was still unpredictable.
Now i'm in a Hydrostream Project with a 2L V6 Mariner that, i do believe, has a lot more potential than the GT-150.
JackoGlastron GT 150 W OMC 140
Glastron GT150 w OMC 235
Hydrostream Vision with 2.0l 135
Hydrostream HST w 3.0L 225
I know two things that are infinite, the Universe and Human's Stupidity, although I am not sure about the first one.
04-17-2006, 01:48 PM #77000 RPM
- Feb 2005
- seattle
- 2,654
- 17
- 33
run of thumb is not to put the tank or any other weighty item in the front. a 115 should put that boat in the 55 mph range. with the tuned exhaust almost 60.
