Results 1 to 15 of 22
Thread: Proper setback
02-07-2006, 09:46 AM #1Screaming And Flying!
- Mar 2003
- Belvidere IL, FARM
- 7,736
- 102
- 115
- 1556
- 514
Proper setback
I have been told and I might add I have read as well that the proper amount of set back is typically 1" for every 1' of your boat. So if I'm running a 20 foot boat I should have 20 inches of set back from my last running surface. Here comes the question, what do we consider the last running surface, like on stv,s that have that extra on there transom do you measure from the last part of your pad or the last part of that extra area i'm referring to??
God, Country, and Fast Boats
02-07-2006, 12:08 PM #2Screaming And Flying!
- Mar 2003
- 7,736
- 102
- 115
- 1556
- 514
Anyone.......anyone..............
BUELLER.............??????????????????????
02-07-2006, 07:48 PM #35000 RPM
- Dec 2003
- Ponchatoula, La.
- 149
Setback
I have never heard of that particular formula for determining the proper amount of setback. I'd be interesting in reading that article if it is available.
02-07-2006, 07:55 PM #4Screaming And Flying!
- Sep 2003
- shreveport,la
- 5,497
- 18
- 24
- 212
The amount of set-back is measured from the last wetted surface while the hull in on plane... Let us know your about your rig and set-up, and we'll try to help you if we can...
Kevin Kiser
02-07-2006, 08:00 PM #5
I think the the "propper" amount of setback is more of a factor of your hull/motor combo. Also....one persons "ideal" setback may be different from other peoples. It all depends on your setup.
Ian
...boatless for now.
02-08-2006, 06:11 AM #6Screaming And Flying!
- Mar 2003
- 7,736
- 102
- 115
- 1556
- 514
Originally Posted by Ted Stryker
ChrisGod, Country, and Fast Boats
02-08-2006, 12:59 PM #7
02-08-2006, 01:05 PM #8Screaming And Flying!
- Mar 2003
- 7,736
- 102
- 115
- 1556
- 514
hey Bash
I did do a search BEFORE I posted this thread thanks for the post, like I said that's what I was kinda thinking just need a little reasurrance.
02-08-2006, 02:34 PM #9
02-08-2006, 05:02 PM #10Screaming And Flying!
- Sep 2003
- shreveport,la
- 5,497
- 18
- 24
- 212
I'm assuming your hull is the Gambler that is a Bass boat made in Florida... I've never owned one, but I'm thinking it is around a 1500-1600 lbs. hull... 11" of set-back is a reasonable jack plate I would think, provided you have a good biting 3-4 blade prop... A Tempest and Trophy props are great props for full size Bass rigs..
Kevin Kiser
02-08-2006, 10:18 PM #115000 RPM
- Dec 2003
- Ponchatoula, La.
- 149
Proper Setback
I use to sell Gambler Bass Boats manufactured by Maritec Industries, Bob Ackerbloom and am familiar with your hull which is 20'3" if I remember correctly. 10" of setback was the magic number on that hull. Predator props performed really well along with the older A40 and A45 series Trophy and Tempest. The M series which we referred to back then as the Pro Series from Yamaha also performed very close to the Tempest. We use to run 26" pitch with stock 200 Merc EFIs.
02-08-2006, 10:46 PM #12Screaming And Flying!
- Sep 2003
- shreveport,la
- 5,497
- 18
- 24
- 212
My Father used to own a 1994 21'10" XDC Bullet that performed exceptionally well with a 27" pitch Predator 4-blade, great props... The Bullet had a 1994 XRi 200 Merc and it ran 82-83 mph unloaded with a 14" jackplate and the factory Alpha style gearcase... The engine was as high as we could get it while still retaining full water pressure with the factory pick-ups...
Kevin Kiser
02-09-2006, 06:10 AM #13Screaming And Flying!
- Mar 2003
- 7,736
- 102
- 115
- 1556
- 514
02-09-2006, 06:17 AM #14Screaming And Flying!
- Mar 2003
- 7,736
- 102
- 115
- 1556
- 514
Great info..............
02-09-2006, 07:50 AM #15
Set back
Moving the engine farther back does several things.
1.) It moves the WEIGHT of the engine rearward, and changes the balance of the boat rearward. This makes the boat harder to plane off, but it is easier to carry the weight at speed and can give a bit higher top speed.
2.) It gives the lift of the prop more leverage to lift the bow of the boat with less positive trim. But it also reduces the effect of tail lift from the prop.
3.) Most importantly, it allows the prop to be raised relative to the bottom of the boat. This can give an improvement in top speed with a slight loss in the ability to plane off. The general rule of thumb is that every inch you move rearward allows the propshaft to be raised 1/8 inch.
A boat with too much setback has a hard time planing off, and can be "squirly" to drive. Finding the correct amount is part of set up of any boat, and the amount of power, gearing, and choice of prop(s) plays a big part.
I hope this helps.Disclaimer: Everything I post is just my .02, and should be take only as opinion. These opinions tend to be notoriously WRONG, and any that are correct, can only be attributed to my being dropped on my head as a small child - repeatedly.
