Results 1 to 5 of 5
    Jul 2016
    columbia sc
    brucato svs cleaner fuel injector cleaned...
    need to have some fuel injectors cleaned and tested. who should i have do this. also anyone know the best way to clean up a brucato svs after removing this. its just really dirty. thanks, Matt
    also have a slightly damaged front half and a promax 300 head that should be fixable thanks again, Matt
    also trying to learn how to post pics when i get this down i will post
    Ft. Lauderdale, Fl
    Pretty much any reputable injector shop can clean and flow the injectors, but I like Brucato because he has plenty of experience in the outboard stuff. As for cleaning the intake, either find someone with a ultra sonic tub or you can soak it with power tune, sea foam or the like......
    Matt I do Injectors. Im in North eastern NC. PM me if I can help. I do a Initial pressure test to determine if any of them leak a Flow test and document the results. I remove the screens and hoses if applicable. Do a Ultrasonic cleaning and and a final Flow test at Idle, Mid Range and WOT up to 9900 RPM's. All data is documented on a Spread sheet. I do not claim to adjust or calibrate them. If they dont come in with a Cleaning and flow or a reverse flush I recommend replace them.
    TX......somewhere?
    Quote Originally Posted by HStream1 View Post
  5. Thanks HStream1 thanked for this post
    Likes Onetime liked this post
    Jul 2016
    columbia sc
    Hstream1 pm sent
  1. injector cleaner
    By skeeter91 in forum Technical Discussion
    Last Post: 07-12-2016, 02:45 PM
  2. Mercury Tech: Can I run an Fuel Injector Cleaner through my 200 EFI
    By Adam in forum Technical Discussion
    Last Post: 06-15-2009, 09:13 PM
  3. injector cleaner
    By daklane2000 in forum Technical Discussion
    Last Post: 03-10-2008, 07:06 PM
  4. Injector Cleaner?
    By Massbasser in forum Technical Discussion
    Last Post: 05-31-2006, 07:55 AM
  5. Is it ok to run fuel injector cleaner?
    By skydog in forum Technical Discussion
    Last Post: 05-01-2006, 06:53 PM
