Results 106 to 120 of 156
01-06-2018, 08:59 AM #106
Stock MontyMan "pro/gas" powerhead ...
This is the "waterski" 6 guzinta 1 pipe ...
powerabout thanked for this postCaptain75 liked this post
01-06-2018, 09:12 AM #107
On the cc volume, one size don't fit all. If your not gonna turn crazy rpm, a tighter cc is usually beneficial. You can widen your ports in cylinders to get more flow to get more charge in cylinder and increase cc pressure to bring velocity back up at low rpm. It'll also allow the cc pressure get below atmospheric pressure sooner at bdc and allow reeds to open sooner to maintain flow through crankcase to cylinder before transfers close, then fill cylinder volume more efficiently once ports close. At really high rpm levels you can get to a point of deminishing returns where the extra pressure causes more drag than you are gaining from the stuffing. Also you can lose low end power if your cc pressure is more than needed and allows too much charge to escape through exhaust port at low rpms.(usually the case with high blowdown degrees between exhaust port and transfer openings and a strong scavanging exhaust set up). So in a nut shell you'll need to experiment with your particular engine/porting design.Last edited by FORBESAUTO; 01-06-2018 at 08:21 PM.
spybot liked this post
01-06-2018, 09:16 AM #108
01-06-2018, 09:17 AM #109Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
Thats way way longer than stock, like has doubled the length of the exhaust.
I wonder how that looked on the dyno compared to without it?
Stock has nothing under the adapter as the collector is in the middle of the case not at the bottom.Last edited by powerabout; 01-06-2018 at 09:43 AM.
01-06-2018, 01:16 PM #110
Yeeesss . Besides cool , it knocks 100+ pounds off of the outside of the transom ...
Not for the faint of wallet ..
Next opening is sometime in March ..
Month ( or however long I can stand motorhome livin in the Keys ) vacation in May ...
poweraboutThats way way longer than stock, like has doubled the length of the exhaust.
Chaz = thinkin , V-6 JohnRudes only came 20" and longer . I could have swore the exhaust come out the prop hub ...
01-06-2018, 08:18 PM #111
01-06-2018, 08:54 PM #112
To add a little twist to the crankcase volume controversy. You always hear how by lowering the volume it helps low end, but it also can help upper rpm power to a certain extent. By lowering the cc volume (1) cc pressure is increased allowing cc pressure to be above cylinder pressure at the point the transfers open at higher rpms (2) increased velocity helps charge and push burnt gasses out quicker at higher rpm (3) also allows cc pressure to drop below atmospheric pressure at bdc sooner allowing reeds to open and create a continuous fresh charge flow all the way through transfers until they close by reducing area to evacuate (a larger volume can act like a storage tank). It can hurt low end also by overdoing those three points at a slower piston speed, but to counteract it you can open a booster(s) port a few degrees earlier to help bleed off some pressure at low rpm and that little bit won't make any difference at higher rpms. I feel you won't to try and have the cc volume to where it can achieve just below atmospheric pressure at bdc at your desired rpm to get the best cylinder charge in the last half of transfer port duration. You just have to play with it and see what works best for your application.
01-06-2018, 09:47 PM #113Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
nosub also said in testing engines and increasing cc comp you would lose VE as it started to heat the mix up too much at high revs
I wonder if he will start reposting one day???
01-06-2018, 09:57 PM #114
Not about outboards but have a look
Some of you may find this interesting
https://www.youtube.com/watch?v=O8e92MgD3LA&t=414s
Andy
01-06-2018, 10:12 PM #115
01-06-2018, 10:21 PM #116
01-06-2018, 11:37 PM #117
To the conspiracy theorists and passers of useless inaccurate information ...
Suck / blow on a 15 ~ 0 ~15 psi gauge , thats what I thought .. couldn't move it off of zero.
Now hook it up to the crankcase .. pumps between 5 - 7 psi positive .
Got any logged data that shows vacuum anywhere from transfer opening to where the piston starts slowing as it is approaching BDC ... ???????
Got facts ???? __________________________
At least build a poor mans Spintron with an electric motor and a strobe light ... before ... naaaa ... keep up the self deception .
Chaz = thinkin I do like how the theory has went from scavenging meant nothing . To that's all that matters now ....
Tip of the day ... plant your seed now , you too will have a grassy knoll by summer ...
FORBESAUTO thanked for this postFORBESAUTO, R.grover liked this post
01-07-2018, 07:37 AM #118
The point where the charge flow will go from intake through reeds directly to cylinder that is evacuating needs to happen as close to bdc as possible. Any latter than that and you are filling cylinder with a charge that is (1) hotter than the would be charge directly from the outside (2) there will be a dead spot in flow at the transition point going from positive cc pressure to below atmospheric pressure where the flow will resume from externally. And you won't this transition to happen at the point where the piston is moving its slowest, which is at bdc. It cannot possibly happen very much prior to bdc due to the fact of the downward movement of the piston is gonna increase cc pressure regardless of all outside influences. What I'm saying is that a too large of a volume can also cause the transition point to be too late due to the fact of it taking longer to evacuate the larger area and too little volume can also cause it to be too late because of so much pressure it can't all get out in time, then you have the problem of the hotter than could be charge entering the cylinder. And the required amount of volume needed changes with rpm, scavanging capabilities of exhaust, port durations and flow capabilities.
01-07-2018, 11:22 AM #119
Jennings mentions an intake valveless 2 stroke powered generator in the TTH from the stoneage of modern 2 stroke understanding. My experience with my reed valve converted Kawasaki 350 triple was the same; with a bunch of blown out/broken reeds the motor was impossible to kickstart, but could be hill started and would run above idle OK ... and screamed on top end just fine. Couldn't start it, wouldn't idle, but would still run 110+
01-07-2018, 12:30 PM #120
I don't get the part of what you are saying about Jennings's work being outdated. Its not outdated, it remains the foundation that all the rest is built on. Granted, the tower is now very high, but it still stands on the same foundation.
