Results 16 to 23 of 23
06-29-2016, 02:39 PM #16Member
- May 2016
- Michigan
- 50
- 10
Joe do you have a contact number I have tons of questions
06-29-2016, 02:48 PM #17Member
- May 2016
- Michigan
- 50
- 10
I'm going to figure this outboard game out ha ha but what are remote pick ups? Sorry for the dumb questions
06-29-2016, 02:53 PM #185000 RPM
- Feb 2004
- 122
- 20
- 12
- 85
- 61
NICE PAIR liked this post
06-30-2016, 08:16 AM #19Member
- Mar 2006
- Boynton Beach, FL
- 74
- 13
- 18
Here is my transom mounted water pick-up feeding twin 2.5 260's. I was one of SangerSully's tire kickers, but this one popped up local to me, and I went for it. Point is, I bought it this way, and probably can't help more on this discussion because I did not rig it. I can take more pictures if it helps.
Beer will not solve all of your problems... but neither will milk!
2005 Lightning 18' Action - 150 Optimax - SOLD
1982 Eliminator Daytona 23' - Twin 260's - SOLD
2012 Concept 32FE - Twin 300 Verados
07-01-2016, 12:51 AM #205000 RPM
- Jun 2009
- central minnesota
- 770
- 30
- 24
strainer plate looks LARGE,did boat have single at one time?-th
07-01-2016, 08:35 AM #21
RiKuY, Your water hoses are running straight into the engines. Do you not even use the water pumps? I've seen the transom mounts feed the lower unit water pump like whaere a nose cone hose goes but have never seen them go straight to the motor. Any cooling issues at idle or low speed?
Thanks1990 Shadow bass boat w/ 2.4 200 Merc. Totally resto'd boat and love it!
07-01-2016, 10:05 AM #22Member
- Mar 2006
- Boynton Beach, FL
- 74
- 13
- 18
I believe this hull started out with a single outboard, mn808gade. I said the same thing when I saw the set-up, that plate is a LOT bigger than it needs to be. Rgsauger, the water pumps are still in and function. These are the 2-hole CLE's, so idle pressure is low, but temperature has been stable. Seems to be on par with what I have read on 2.5 260's with 2-hole CLE's. It is nice to know water pressure and amount moving through the engines is great, even when turning.
03-30-2017, 01:24 AM #23Banned
- May 2016
- Bean Station Tn.
- 314
- 53
- 10
- 65
- 50
How wide of a transom do you need ? ...I have a seebold tunnel and the center is set in ...tryen to see if I have room for twins mercs...
