Results 1 to 15 of 32
Thread: AutoCad and Inventor
11-29-2004, 01:15 PM #15000 RPM
- Mar 2003
- Aurora Ontario
- 869
- 12
Is it possible to use these programs to draw a boat and rendor the image, I am currently using cadkey and cant get drawings to rendor... I have all 3 programs availble at school, Also any tips, advice and examples.. Thanks
Bryan
11-29-2004, 01:56 PM #2
just curious what you mean by rendor
warren1996 ALLISON GSE
11-29-2004, 02:10 PM #35000 RPM
- Mar 2003
- Aurora Ontario
- 869
- 12
um, by rendor i mean to make the 3d wireframe become a shaded solid.... in cadkey v21.5 when i go to make an oject with like the shape of a boat shaded it becomes flat... yet when i rotate the 3d wireframe image it looks normal... i hope this can explain it a little better
11-29-2004, 02:23 PM #4
its render... and you can draw and render anything you want if you have the skill. I'll see if i can dig something up.
jim> Stainless steel Merc cowling plates - $110 shipped TYD - LINK <
11-29-2004, 02:31 PM #55000 RPM
- Mar 2003
- Aurora Ontario
- 869
- 12
ohhh render, 1 badstream that would be good if you could find something, or give me a few tips....... why wont my drawings in cadkey render properly, extruded solids render fine, but not curves???
11-29-2004, 02:39 PM #6
thats what I thought you meant, never had a problem before, I will play around a bit and see what I can find
11-29-2004, 02:44 PM #7
if cadkey is designed as a 2D program, it is never going to act right with 3d stuff. use solidworks or inventor or PRO-E...
here is a micro water pump about 10 times bigger than it actually is... i designed and machined it for my RC boat... the bolt holes in this are 2-56 threaded> Stainless steel Merc cowling plates - $110 shipped TYD - LINK <
11-29-2004, 02:51 PM #8
1badstream has a point, cadkey v21.5 is a very bad solids program, it only got better when it became key creator. I use key creator now and it is as good as solidworks, but cadkey for solids wasn't very good.
1996 ALLISON GSE
11-29-2004, 04:00 PM #95000 RPM
- Mar 2003
- Aurora Ontario
- 869
- 12
thanks
the only reason i would use cadkey is because i have the most experience with it.... how would i start to draw a boat with inventore, i can draw simple shapes and extrude them but i am totally lost when it comes to creating curves and making them solids.
11-29-2004, 04:10 PM #10
Have you tried 3d Studio Max? I find inventor is too limiting if your trying to make anything like a boat, car, etc. I'm making a 69' Yenko right now and I've only been using the program for 2 years. That reminds me, I gotta get on that jackplate
89' Hydrostream Vista 200XP
Delta 3cyl FORCE
11-29-2004, 04:16 PM #11
im not limited by inventor, you just gotta know what buttons to jack off.
11-29-2004, 04:17 PM #125000 RPM
- Mar 2003
- Aurora Ontario
- 869
- 12
10.5... i drew up a jackplate in cadkey, i took the dimensions off my vector, minus the setback.... how far are the hole centers on your motor, it was to dark to measure mine last night...
Bryan
11-29-2004, 04:18 PM #13
Don't get me wrong badstream, I used inventor for all the detail components (engine, suspension). But for making the actually body, max works better for me.
Delta 3cyl FORCE
11-29-2004, 04:20 PM #14
Autocad with the mechanical desktop is a very good 3d solid program if you have acess to that. You can do it with "regular" autocad 3d shapes, its just a little harder. No matter what you are gonna have to figure it out what the best/easiest method to get your desired results. I'd start at the transom and try extruding that along a path.
Paul V.
1987 Hydrostream Viper - 1973 V4 Evinrude 135 Crossflow "Shiny Motor"
11-29-2004, 04:21 PM #15
Holes eh, I'll go check. Mine will be weird though, damn force
Delta 3cyl FORCE
