Page 2 of 2 FirstFirst 1 2
Results 16 to 22 of 22
    May 2001
    Hickory NC
    Mid range versions are about a year away
  2. #17
    Dillon Beach ,CA
    Re: hmm
    Originally posted by wing nut
    im *guessing* that its the motor mounts, rubber maybe?
    scott
    You might be right wing nut, since he was talking about a race I just assumed it would have solid motor mounts. but a guess if its a production class. it could be rubber(dampers).
    ...Jeff Akers...
  3. #18
    Aug 2002
    Grand Rapids, MI
    Are the V4s out now? They show 100/115hp. Here is another page I found: http://gov.evinrude.com/evinrude.html
    You think my bayliner would go faster if I pulled the 85 force off and put a 90 etec on it? lol
    Found DI motor specs there too: http://gov.evinrude.com/evinrudecomp.html
  4. #19
    Aug 2004
    Lake Wissota, Wi.
    mid Etec
    V4
    Evinrude E100 100 Electric Start Remote Steer* Standard 369 lbs
    Evinrude E115 110 Electric Start Remote Steer Standard 369-375 lbs
    335lb. Vector, 750lb. Ventura II
    Hydrostream Addict Hot Evinrude 200 crossflow
  5. #20
    Aug 2002
    Grand Rapids, MI
    I've been told here my old 1500 inline is about 115 prop hp and 325lbs? My 85hp force triple is 275lbs in the manual including integral trim. They just can't get the weight down with all the new stuff on them...but I know they are a lot better.
  6. #21
    Oct 2003
    Cobourg, ON
    Weight
    I think the E-TEC, because it has far less steel parts than the Verado, is more likely to do well in a weight reduction exercise. Heavier motors are here to stay, but as we all know weight reduction is the best path to better performance.
    When I bought the 15 for my Zodiac, I really wanted a four stroke just for the increased range. I was cured of that when I tried lifting one! It's hard enough lifting a 75 lb. two stroke over the transom onto the platform, then onto the Zodiac.
    Can't wait for the 15 E-TEC!
  7. #22
    Gothenburg, Sweden
    Dampers
    Espen is indeed referring to the engine mounts.
    Norwegian and Swedes call them dampers since they dampen vibrations. (Unless they are solid, that is)
