Page 4 of 24 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 LastLast
Results 46 to 60 of 360
Thread: laser owners
  1. #46
    May 2002
    NY, Long Island
    tony how much setback are you running on that thing?
    "If everything's under control, you're going too slow"
    -Mario Andretti-
    76 vixen,.. on the back burner
    82 laser comp. 380 ray
    PICS OF THE VIXEN REBUILD
  2. #47
    May 2001
    New Hill, NC
    I'm running 6 1/2" setback now. I started out with just 3" because I was worried about the weight of the OMC motor.
    It handles much better now with the extra setback, but I've got a little more ballast in the drivers seat than you do and I have the battery mounted in front of the driver.
    Tony Brucato
    (919) 718-0249
  3. #48
    Houston.Texas
    here are mine...
    1983 Laser LTV w/ 2.0 Merc
    1986 Laser 160V w/ 115 Merc inline six
    1992 STV Scorpion w/ 75 Johnson
    1979 Laser 2500 basser w/ 200 Mariner
  4. #49
    May 2009
    Southeastern Ky
    Well looks like I have found a new home...lol I just bought a 1988 19' Laser 3880 Flippin bass boat. I got it Sat. It has a Suzuiki 175 oil injected motor on it right now but it has a burnt piston. I was going to put my Johnson GT 150 on it because I know nothing about a Suzuiki motor. Well just wanted to say hi to all the Laser fans and get your opinions on the 3880 Flippin since I haven't seen it mentioned.
    DJ
  5. #50
    Houston.Texas
    Quote Originally Posted by DJ_28 View Post
    DJ
    Hey DJ.. welcome!!!
    the 3880 is a great bass boat! same hull as the 380 Ray. My uncle had a brand new one back in '89 i believe..with a 200 Pro Max.. ran mid 80's!
    jeff
  6. #51
    May 2009
    Southeastern Ky
    I know mine is a 88' and it says it is only rated for 185 max hp. I haven't had it on the water yet but I can't wait to see how it does. I wonder what it will run with the 84' Johnson GT 150?
  7. #52
    Houston.Texas
    post some pics!!
    jeff
  8. #53
    May 2009
    Southeastern Ky
    I will if it ever stops raining...lol
  9. #54
    Jul 2008
    Mayfield, NY
    I bought this one last summer ..... I believe it's a 420. It's an '87 21ft with cuddy.
  10. #55
    Lindenhurst, NY
    I had a 1987 420 Laser with a 200 XP Evinrude on it. The Boat is in the Laser Boat catalog from 1990. I also had a 1989 380 kevlar hull center steering with the same engine on it. 420 ran 84 to 87 mph and the 380 ran 92 to 96 mph depending on the day. I still have the original catalog for these boats. I miss both of them, they were a blast to drive.
  11. #56
    May 2009
    Southeastern Ky
    How do these boats do in rough water? I fish alot on bigger lakes when I can and was hoping since it is a 19' boat that I would ride good in choppy water. Don't get me wrong I know very few boats perform good in waves bigger than 3 feet or so. What I'm mean is, will it bet you to death in choppy water. I have been in a couple of newer boats (18' and 19') that made you feel like you were a couple of inches shorter I moderate waves let alone a 2 to 3 foot chop.
  12. #57
    auburn, ma
    my dad had a 388 (19) and it handled it 1.5-2s with a pretty smooth ride crusin at ard 40-50, but he bought a 422 (21') and it takes them lk ur on flat water.
  13. #58
    auburn, ma
    i called up laser a few years ago seein if u could still get the 422 new, but they said the mold went to hell sitting outside
  14. #59
    Fort Worth, Texas
    DJ, the Laser is a SWEET big water boat... not "too" big, but you know... I've been in some pretty good sized stuff and never had any problems. They are a driver's boat for sure though.
  15. #60
    Celina, Ohio
    380 Laser
    I am in the process of putting together a 380 Laser. It is a 1987 model. The boat was stuffed in the early 90's and it put a hole in the front deck and blew out the back corner of the deck. I just about have the boat repaired. It weighs right around 600 lbs bare(it has no floor,just stringers and no foam). It came with an almost new factory interior. I figure it should be about 1200lbs rigged ready for the water(without driver). I have a pretty healthy 2.5 Merc that I am going to hang on it. The engine should pull around 300 hp(without the nitrous). My questions are about set up. With this kind of power should this hull need much setback if any? Also a good recomendation for a prop on this hull with this kinda power(it's just a lake/play toy so top speed is my only concern).
