Results 1 to 9 of 9
Thread: Does anyone recognize this DAH?
06-06-2004, 09:38 PM #1Member
- Jun 2002
- Washington
- 78
Does anybody know what this prop is? It is a DAH and measures approxamaetly 12-1/4" in Dia. It looks like it fits a 7/8" splined shaft but only has splines on the last 3/4". The hub is 4" long and looks to have a tapper in the front hub i.d.
06-06-2004, 09:38 PM #2Member
- Jun 2002
- Washington
- 78
One more picture:
06-06-2004, 09:55 PM #3New Member
- Jun 2004
It is a prop with a very ugly finish... What do you want to do with it? Where did it come from?
Abby °Ü°
06-06-2004, 10:31 PM #4
prop
That prop looks like one of the 2 that I have for my Stinger GP. What's the pitch? I have a 23 and a 26. It looks exactly like the ones that I have. I'll see if I can find a picture of mine later tonite.
[SIGPIC][/SIGPIC]
06-07-2004, 02:05 PM #5
DAH prop
here is one of mine
[SIGPIC][/SIGPIC]
06-07-2004, 04:05 PM #67000 RPM
- Central Florida
- 2,643
- 37
- 32
- 219
Clearly has the OMC factory mark and is either a three cylinder or V4 prop. The small diameter suggests three cylinder but it could be a cut down V4. Looks like some of the old teflon coat is still there.
06-07-2004, 08:00 PM #77000 RPM
- Central Florida
- 2,643
- 37
- 32
- 219
Every OMC three I know of has 13 splines just like a V4. Shaft on the small case for the 15" engines is shorter but still has the same splines.
06-07-2004, 10:51 PM #8
Looks like a couple V4 solid hub wheels I have.
Could also be one of the ones used on the early stingers 3 cylinders from the factory.2006 Action Marine Comp
1980 Ventrua 2
06-07-2004, 11:10 PM #9Member
- Jun 2002
- Washington
- 78
Thanks everyone. I think you guy's are correct about the early 3 cylinder OMC's. I got the prop with an old 15", 65 HP Evinrude and some other misc. stuff from a guy who used to race tunnel boats.
Can anyone decipher the pitch from the numbers stamped on the hub? It has a 25 24 CC DW stamped on it. It also has another, smaller 25 stamped under the 25 24 and on the other side it has a 384137 stamped. It also has a little "M" surrounded by a box.
Thanks again, Mike
