Results 1 to 4 of 4
Thread: mark 5 ?
    #2 iron from the Mayo clinic, Fla. / Blue Ridge, VA.
    Question mark 5 ?
    one at a flea market seems to have good compressin in reasonable condition for 150. considered 100. sale is over tomorrow. any input would be appreciated. fun out
    most overnite successes usually take at least 10 years
    Certified turd polisher,
    Nov 2002
    North Bay, Parry Sound
    Great motor, but check the lower unit. These and the mark 6 had gears of glass, also the gearcase was prone to splitting. Lots of these engines around and they do run nicely and are light. 100 would be okay if the engine is running and gears are oka. Otherwise if you check ebay you can often find a restored one for 300 - 400
    thank you mk30!
    the guy kept fiddling and talkin, need to put some starting fluid to her and listen. thanks again, fun out
    May 2001
    Missouri
    MK5
    fun, keep looking. you can usually find them in the $30-75 range needing a little tweaking. I sold two on eBay last year for $75.
    There seems to be alot of them around still...
    Jason
    Outboard Junkie
