Results 1 to 15 of 20
    #2 iron from the Mayo clinic, Fla. / Blue Ridge, VA.
    Unhappy i want to make my rear end tighter!
    got a backup truck, dodge 150 ram, 82 model. kinda light in the rear. thinkin some coil over shocks, maby airshocks? helper springs? air lift bags? just a little loose changing lanes, or any weight at all. just want to stiffin her up a bit. suggestions? fun out
    most overnite successes usually take at least 10 years
    Certified turd polisher,
    Voorheesville, Upstate NEW YWAK!
    How about a sway bar.
    Tom
    Aug 2002
    Grand Rapids, MI
    I had a ranger once that had new springs in the front and 2 extra leaves added to the back, still was not real high. I could load it with weight and it did not squat, but it wagged tail with a 19' I/O like crazy and was tippy with even with only weight in the box. First part of the problem was the tires. The sidewalls were soft. I got some new tires I could put 50psi in for towing, but they were better even at the normal 30psi and great at 50(old tires only rated for 35psi max). Still felt funny sometimes. Used another ranger once and it felt fine with no wiggles. Climbed under there and yep, it had a rear sway bar. Both had the same front bar. So I went to the boneyard and got one and bolted it on. It worked great and the truck drove much better too.
    I would not bother with the springs unless it sags. Get a sway bar and check the tires. More sidewall ratings and/or higher psi ratings help a lot. It will ride harder with more pressure, but mine seem to ride good when I let them back down. Now I got a bigger 3/4 ton, and can't find anything that bothers it. With those junk tires I could push on the ranger's box side and get the truck to wiggle sideways on the tires easily.
    I don't piss with it now; I had a guy I know just about die when his trailer wipped and rolled the whole rig a few times, then caught on fire. I had a job once driving delivery, and drove dual tire pickups. They don't move with a trailer on, big difference from all those sidewalls. I'd get one but they suck in the snow and I really don't need a 1 ton.
    I also had a lose hitch cause a wiggle with an old reese type once. I drilled a new hole further in for the pin to make it tight again.
    Sunny Ca
    Rear end
    Do a 2/4 drop with Eibach 2in drop spring in front and 4in shakles in back with Hellwig or Hotchkis sway bars with some 17in rims
    and edelbrock shocks
    1 Newbie
    SW Florida
    My wife has a great bun buster DVD you could borrow.
    2004 Hydra-Sports Vector 2600 - twin 225 Yamahas
    WASHINGTON N.C.. I TOO HAVE A BOATING PROBLEM
    Try some allum.
    J/K
    JOHN MASON
    '83/VECTOR/MERC 200-- SOLD
    '98 Quartershot T-3/ MERC 200
    "If your not living on the edge, your taking up to much space"
    Fort Lupton,CO
    Just replace the springs. I found a site years ago. http://www.espo.com/
    They sell new everything for the old stuff.
    Fellow G-Man,
    Sunshine Syndicate, Mid West Chapter
    1975, 16' Checkmate Tri-mate 2.4 200+
    Currently undergoing overhaul.
    Thumbs up thanks guys!
    sounds like a sway bar is a must. checkmate, good source. 96819, do you have experince with this setup? i have seriously considered dropping it, it's a LWB in perfect condition bodywise, just dont a goofy ride, like the softness of the LWB. HUN+ maby i could drop a crate V-10 in her? fun out
    Aug 2002
    Grand Rapids, MI
    Florida.
    Around New Years a guy offered to give me two old mid 80s Ram 1500s. Said one drove ok, other needed help. I told him I was not going to dig the snow out to get them, so they would have to wait until spring if I even want them. He said OK. Just about forgot about that.
    Sunny Ca
    Re: thanks guys!
    My experinces is with Silverados but thats the easiest and cheapiest way for a all around sport truck.
    1 Newbie
    Kissimmee, Florida
    Drop it, sway bar, and good shocks
    Shocks with variable damping work pretty well as an all around choice. Monroe has been replacing their Magnum series with a line called Sensatrac which are variable. I have installed a bunch of these on all kinds of trucks, and they work well, and aren't terribly expensive. Wheel and tire selection will make a pretty noticeable difference too. Lightweight wheels and lower profile tire with relatively stiff sidewalls can make an enormous difference in road holding ability, provided they have a good foundation to work from (springs, sway bars and shocks). Another good idea if you really want a corner burner is polyurethane suspension bushings. Even replacing the sway bar bushings and end link bushings with poly can make a noticeable difference. Let me know if I can help ya.
    Rickracer
    Sunshine Syndicate Member
    There is a fine line between "hobby" and "mental illness."
    [img]http:/
  12. #12
    Lightbulb thanks Rick!
    i forgot about your "lil green monster" thats kinda what i'm lookin for sept in a full size "old schooler". i'll be in touch, hope all is well, tell everybody i said "HEY" fun out
  13. #13
    Long Island NY
    loose changing lanes?
    Just something to think about. it sounds like your getting that wondering in the lane on the highway. now add a trailer and its 3x worse. first I'd check all the steering joints. next check the back lash in the steering box with the steering wheel. If there is too much play there you can adjust the screw on the steering box to get the play out. while your down there you can quickly check the alignment with a tape measure. measure across the front of the 2 front tires then measure across the back of the 2 front tires. the difference should be 1/4 inch less on the front side. wheels that toe out will wonder. The trailer only adds to the problem. the more tongue wieght the better it will handle. 75lbs or more is good.
    Helmut
    slow boats
  14. #14
    Thumbs up all good thoughts STV,
    this is info i never really considered. i hope this helps other folks in their "TOW" part of the "TOW n GO" equation. that was a segment in Hot Boat before it got all commercial. for those in Reo Linda, the tow refers to your rig and your go is your SCREAMER! fun out
  15. #15
    Long Island NY
    yeah, and the roads that are indented where the tires run are the worst. the wheel will keep trying to pull when you get close to one side of the lane and then you over correct it and then the other wheel will pull the other side. now your swirving all over the place. I know the feeling. I had a bronco with alot of miles that did it until I fixed the front end.
    Helmut
    slow boats
