Results 1 to 15 of 21
Thread: Merc intake bleed lines
11-20-2003, 03:39 PM #1
I've been going nuts trying to find the small gas hose used on the Merc 2.5 intake, for the bleed lines. Seems nobody nere carries anything remotely small enough, and still hold up to gas.
The light bulb finally came on,,,, damn gray hairs/slow switch....
The local hobby shop that carries all the gas powered cars/trucks/planes/boats and such has rolls and rolls of colored Tygon tubing, wild ass colors too if needed, neons and such.
about a buck a foot.
Always make sure to check yer hoses when yer running yer motor on the hose, you might be surprised where you will find a leak....
RussRuss Benton
Allison XB-2003 w/JSRE Pro Max
Allison XR-2001 w/260 +
11-20-2003, 03:49 PM #25000 RPM
- Courtice, Ontario, Canada
- 980
Russ,
Good info!!! I am replacing all my bleed lines this winter and was wondering where to get it.1996 Allison GSE /200XS
1977 Hydrostream Ventura / 150 Mariner MAG III
11-20-2003, 04:07 PM #3
gald the info already helped somebody
I was at wits end trying to find that stuff out here in new mexico, no Hi-Po Merc dealers here. I've spent a week looking at all the wrong places.
I have a little RC type hobby shop right by the house and never gave it a second thought, till after the 6th or 8th Corona the other night, dinking around in the garage with the boat......lol .
Lemme know If ya need some, I can pick it up fairly easy if needed.
RussRuss Benton
01-05-2004, 06:24 PM #4
found some
napa has it by the rolls. .95 a foot you need about 10 feet for 2.4 carb motor
01-05-2004, 07:12 PM #5
None at my NAPA here
Dude,
I tried NAPA, Autozone, Checkers, Home Depot, Home BAse, True Value Hardwares, you name it,,,,, No luck !!
I did see at NAPA they carried a rubber windshield hose the same size I needed, but the rubber will begin to break down and introduce particles in yer fuel stream,,,,, be careful it will crack easy too once the gas hits it...
The Hobby Shop had Tygon Tubing, it's gas/fuel rated.
RBRuss Benton
01-05-2004, 07:28 PM #6
Also,
www.hosetechniques.com. I think the bleed line is 3.2mm, but not positive.
ProCompAllison XB02, 22ft Tritoon 225 4 stroke, two seadoo sparks
Past rides 2001 STV EURO, Allison Grandsport, STV RiverRocket, STV Euro, STV ProComp, Hydrostream V-King
RIP RPM RACING
RIP GTS1
01-05-2004, 08:59 PM #7
Bleed line
I use 1/8 inch Tygon gas line . it is a clear green color and it dresses the motor up. You can purchase it at any john deer tractor sales and service or at most lawn mower repar shops.
P.s dont forget to tie strap them all on
JIM
04-16-2004, 07:11 PM #8
Tygon F-4040-A
lawnmower shops carrie it purty regularly.
12-02-2004, 09:09 PM #9Junior Member
- Nov 2004
- Osage Beach.MO
- 22
bleeder lines
We have it in stock.
12-04-2004, 11:00 PM #10
you can get that stuff from grainger as well.
12-10-2004, 09:28 AM #11Team Member
- Sep 2001
- Comanche Texas
- 977
bleed lines
i use the yellow clear type found on chainsaws. it kinks fairly easy though. what is the purpose of these hoses anyway?
12-12-2004, 10:59 PM #12Originally Posted by Steven
12-16-2004, 07:21 PM #13
2 stroke outboards tend to puddle alot of fuel/oil at low speed. The recirc lines carry the unburned mix back into the engine at the transfer port area.
The lines have a one way check valve in them to keep thing moving from the front of the engine to the back. In the old days (before EPA) alot of this excess fuel/oil mix just got dumped out into the water through drain lines in the block...not cool.
12-17-2004, 12:11 PM #14Team Member
- Sep 2001
- Comanche Texas
- 977
bleed lines
thanks guys
12-23-2004, 07:24 PM #15
got
some tygon line today, $1.30 a foot. But hey didn't want to drive all over south OK to find it cheaper. later, james
2000 SS comp Allison, 225 Promax
1971 15R Allison, 1966 110SS I6, with SSM
14' San Marco tunnel SST 60, 50 hp Merc
32" Lapcat II tunnel with K&B 7.5
