Results 121 to 135 of 169
Thread: Mercury Twisters T1, T2, T2X
02-17-2009, 11:09 AM #121
Only knows the last part of it's story, I found it in a barn in Moss ( was an add on Finn.no), before it ended up in the barn, it was used as a display engine in a local shop ( might have been Jeløy Båt, rumor says they had one ?? ), it came with some extra boxes with parts ( some Twister /-1 , T2x and T2 parts)
It's not 100% complete, some parts was missing, but I should make it a runner again .
Some pictures her .
Arne KjetilMy engines :
Johnson V4m-10s 90 hp 1964,from the prosess.
Mercury TII, next project
True story ??:-)
02-19-2009, 11:23 PM #1225000 RPM
- Sep 2003
- 500
- 18
- 27
- 42
Tiix
Here is a 1974 promo shot of the TIIX
02-20-2009, 08:40 AM #12320 Foot Switzer Wing 2 X S3000 (Dust'n the Wind II)
!6 foot Wood Eltro Vee (2X Merc 1500's) (Dust'n the Wind IV)
15 foot Powercat 15C (2 X Merc 1500) (Dust'n the Wind III)
(Single engine boats are lacking something)
15’ Wooden Switzer Shooting Star...
16 foot Lee Craft Merc S 3000-(Gold Dust II)
(The exception proves the rule)
Obsolete and Proud of it
02-20-2009, 01:47 PM #1245000 RPM
- Sep 2005
- 145
I would like to be on the list if the belts become available- for 3.
thanks Rod
02-24-2009, 09:37 PM #1255000 RPM
- Sep 2003
- 500
- 18
- 27
- 42
Twister article
Here is an article from the Merc Messenger Spring of 1971. Hopefully you can read it.
03-05-2009, 02:40 PM #126
timing belts
Me too,in need of two timing belts for TIIX,any idea of delivery time
SST140,TIIX,850XS,650X,Mark30H etc.S 405 XSR
03-05-2009, 06:12 PM #127
03-07-2009, 04:22 AM #1286000 RPM
- Mar 2007
- france
- 1,557
- 13
I'm with you Steve, Last time i saw Becky he was high as a kite in a bar in Torriggia. He had just taken delivery of a brand new LOTUS sports car----If i remember right it was all black in the John Players livery. Said he was taking it back to Wisconsin. Wonder if the car ever made it----he obviously did.
He was supposed to see what sort of nonsense Renato got up to over there, but you wouldn't bet the farm on his success.
04-09-2009, 06:03 PM #129
Any news ??
Have made some progress with plan B, noting conclusive at this point...
True story ??:-)
04-21-2009, 04:43 PM #130
Raymar will be making new gears for his T2 using 1/5 pitch stock. Droll, is that what you are using?
Scott
04-22-2009, 10:58 AM #131
The one pictured are a T5 pulley ( 5mm or .197" pitch , 36 teeth ), will probably work but needs a custom 99 tooth belt, will therefore try a XL style belt/pulley too ( haven't got the parts yet ), as there are more lengths available without custom order..
XL = .200 inch (5.08 mm ) pitch .
Remember to chamfer the side against the old center hub.... without the chamfer the pulley will not fit correctly over the hub .
True story ??:-)
04-24-2009, 12:43 PM #132
Might have a winner here
2 new pulley machined, notice the chamfer on the right pulley.... will not fit correctly to the hubs without it .
( bout pulleys got the chamfer, but the right one lies with the bottom side up , lower pulley are OEM )
Data pulley :
- Profile XL ( pitch .200" or 5,08 mm )
- Number of teeth 34
- Outside diameter 54.47 mm (54.98 mm)
Data belt :
- Number of teeth 95
- Length belt 482.60 mm ( 19" )
- With 9,5 mm ( 3/8" )
Pulleys and belt mounted.....looks promising , might be slightly tight but should loosen up with some use ( belt are brand new... )
Block in picture are a Merc1400 block, parts put together for mock up only....
True story ??:-)
04-24-2009, 01:59 PM #133
Looks good Arne , how much would this conversion cost ?
04-24-2009, 04:18 PM #134My engines :
True story ??:-)
10-28-2009, 04:11 PM #135
