Page 7 of 12 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 LastLast
Results 91 to 105 of 169
  1. #91
    Apr 2002
    Akron, Ohio
    Pics
    Parker, what type are the v-hulls in pic #3 ? How fast was a missle with a twister on it? Thanks. Smitty
  2. #92
    ST.PETE FL.
    5 Thread(s)
    bout 80 or so as much as i can remember
  3. #93
    Dec 2004
    Does anyone out there have a lead on any T2/T2X timing belts. I thought I saw someone on this site who was trying to locate some or have them fabricated. I have a T2 I want to put on a 15' Allison to run this year but I have no spare belts. Any help on this would be greatly appreciated.
  4. #94
    Apr 2002
    Port St. Lucie, Florida
    T2 timing belts
    Try contacting Zonkercraft on this board. I think he was looking into having some made at one time. If that is possible, I will want several of them myself, for my Twisters. I am very close to completion of my T2X on a 16 Ally and could use some spare belts as well. Let me know if you need any help with setup, props etc.
  5. #95
    Celina, Ohio
    I have at least one spare N.O.S. belt that I would be willing to trade towards a T2X exhaust adapter.
  6. #96
    Apr 2002
    If I had a second spare adapter, I would let it go. As you know, they are as scarce as hens teeth. My son has mine and is currently working on building one in CAD to make one on a CNC. Looks like we can do it, but will take some time. Will keep you posted on progress.
  7. #97
    Celina, Ohio
    Thanks, I am getting ready to try to make one myself. I have one but need 2. At least I have a pattern.
  8. #98
    Jun 2004
    Elverum, Norway
    Anyone got any tech data on the timing belt ??
    Like :
    • Pitch
    • Number of teeth
    • With
    • Diameter
    • Mercury part # ( know it's NLA )
    • Are there any other types of belts that will work ??
    Currently looking for a couple myself + some for a friend restoring a T2X.
    Arne Kjetil
    My engines :
    Johnson V4m-10s 90 hp 1964,from the prosess.
    Mercury TII, next project
    True story ??:-)
  9. #99
    Celina, Ohio
    If no one has posted the specs, I can when I get home tonight.
  10. #100
    Celina, Ohio
    The belt is 19 1/2 " long. It is 3/8" wide. It has 68 teeth. One of them also has the number 46 on it. No part # on the box or belts.
  11. #101
    Quote Originally Posted by Droll View Post
    Like :
    • Pitch
    • Number of teeth
    • With
    • Diameter
    Arne Kjetil
    Unless I'm wrong, it has the same pitch and width as a regular belt, what is different is the length/number of teeth - which we now know
  12. #102
    Jun 2004
    Elverum, Norway
    Quote Originally Posted by Mark75H View Post
    Unless I'm wrong, it has the same pitch and width as a regular belt**
    I know, but what's the pitch on the regular belt then .
    Played a little with some old standard belts and found some numbers:
    68 teeth as largecar91 now confirmed
    Pitch = 7,065 mm ( 0.27815" )
    68 teeth x 7,065 (pitch) = 480,42 mm ( diameter measured at the bottom of the teethes on the belt )
    Doesn't fit any industrial belts I have seen .
    Arne Kjetil
    My engines :
    True story ??:-)
  13. #103
    Celina, Ohio
    I said that wrong. The length is 19 3/4" not 19 1/2. I counted the teeth about 10 different times. It is 68. I put it next to a regular belt and it is the same except length.
  14. #104
    That makes the pitch closer to a more "regular" number of .3
  15. #105
    Dec 2004
    Timing Belts
    Thanks Custom Performance 1 for the advice. I too have no spare exhaust adapters for the T2X; My engine is mounted on the T2 tower housing.
    If I break my only T2 belt I will be out of business on this engine and I really would like to run it on the 15' Ally this summer.
