Results 16 to 30 of 169
Thread: Mercury Twisters T1, T2, T2X
10-14-2003, 05:22 PM #16
While y'all are at it, how 'bout findin' somebody that can get some T2/T2X timing belts. I need a REAL NICE T2X cowl and a REAL NICE T3 cowl while y'all are scoutin' around for parts.
I'd like to see some pics of the 20" Twister. I have one that was supposedly an offshore type also, according to a previous owner, but it's 15". It had the wiring harness run out through the front of the pan instead of the side, supposedly for more clearance on a multi engine boat, and also was set up for a shiftable gearcase, which was long gone when I got the engine with a rod through the side of the block.
There's one other Twister/Twister 1 mystery I've never solved: I've seen two different bolt patterns where the exhaust log bolts to the side of the mid section. I can't find a pattern between early and late, and have seen both patterns on both the Twister and Twister 1. Any players on that one???????
Incidentally, my red Twister ran within the last several years. If I hadn't hated the boat it was on so bad, it'd still get dunked occasionally now, but I sold the boat, so now it powers an engine stand.Membership upgrade options: http://www.screamandfly.com/payments.php
10-14-2003, 05:59 PM #17
OK, so who needs T1 Parts?
Keith-
10-14-2003, 06:46 PM #18
Thats cool!
10-14-2003, 07:09 PM #19
There's another.....
1 of those special racing Fitting
Bruster's Mercury solid motor mounts, details here:
http://www.powercatboat.com/Bruster/Bruster.htmlI'm been living in fast forward, now I need to rewind real slow....
10-14-2003, 07:12 PM #20
Remember?
this one
Is there something we don't know here???Bruster's Mercury solid motor mounts, details here:
10-14-2003, 08:03 PM #21
How about T2x parts?
Keith-
10-14-2003, 08:26 PM #22
Looks like a T2 mid to me
The only X suff I see here is the cowl
10-14-2003, 08:36 PM #23
You're right Sam. T2 mid, T2X cowl, home made gearcase adapter. Is any of this stuff for sale?
10-14-2003, 09:18 PM #24
Jeff said it here....
Originally posted by Jeff_G
Only problem is if anyone posts they have something RM gets it!
What we need is a site that bans Norris from the parts for sale section. Hey just pickin on ya!
Kieth,
Hang on tight, we need to see restored running motors, no more saw horse queens.Bruster's Mercury solid motor mounts, details here:
10-14-2003, 09:59 PM #25Originally posted by Mark75H
C-6/T2 mid.Keith-
10-14-2003, 10:11 PM #26Originally posted by Raceman
Is any of this stuff for sale?Keith-
10-14-2003, 10:12 PM #27
All I can tell you is that it is a 1974 serial number, both T2's and T2X's were made in 74, so that is no help. Is that the serial number stamped on the block or the number on a tag somewhere?
If anyone can identify this number as belonging to either I'd be interested in the rest of what they know.
I have a listing for the powerhead and short block part numbers, if the block casting number is close to one of them it might identify it, but sometimes the casting numbers are jibberish as part numbers.
As I once did with Mark20H's to identify how many came with small skegs and how many came with large skegs if the owners of Twisters, T-1's, T2's and T2X's would share the serial numbers here we might be able to figure somethings out.
Ya got one? What's its number? We could all learn somethingLast edited by Mark75H; 10-14-2003 at 10:24 PM.
10-15-2003, 05:18 AM #28
I'm not real sure there was much of a difference between the T2 and T2X powerheads anyway, at least at the time the X first became available. There's no question that there was some development and in-stage change in the X powerheads, but I'm not sure that the change from the T2 to the T2X initially involved anything more than the mid and exhaust plate. It's generally accepted that all of the X powerheads had the twin tubes in the carb venturi, but I've bought regular T2's that had em also. It's hard to say what might've been switched around in all these years, with race parts actually being affordable back then. I've heard of X's with single ring pistons and finger ports, but I've never seen either in any of my engines, and suspect they were mods, rather than factory originals generally available to everybody.
10-15-2003, 08:01 AM #29Originally posted by Raceman
All of the T2x's I ran had a LOT more mid range, and some top end on the prior T-2's....Their were significant differences. I tried ,once, to put an old T-2 powerhead on a T2-x mid section and the thing ran like crap.
I ran Single ring and narrow ring pistons as well as some finger ported blocks but none of that stuff was available to the general public. I believe that the original, for public sale motor stayed virtually unchanged as a product during its approx. three year life span.
T2x
10-15-2003, 08:19 AM #30
Rich I believe they had the narrow two ring piston from the factory, although most today only have the common 3 ring piston.
Never argue with an idiot. They drag you down to their level, then beat you with experience.
3 X APBA Formula V Nat'l Champion
APBA Formula V US-1
It took me 29 years to become an overnight success.
