Results 151 to 165 of 169
Thread: Mercury Twisters T1, T2, T2X
03-01-2012, 01:42 PM #151
Just an idea , maybe the spliced belts would be stronger if you cut them at a 30-45* angle .I would use the same specs as a stock inline leaning to the high side,20/1 oil mix ,100 octane fuel,timing 20-24* depending on fuel. If you go into detonation with these engines it will destroy itself very quickly! Pay close attention to carb setup with float levels , linkage, fuel pressure . These engines are overcarbed so it's critical that all carbs are setup the same.I'm trying some jet changes this year .What are you going to run this on ? What gearcase and props are you using? Glen
03-01-2012, 03:33 PM #152Member
- Jan 2008
- houston texas
- 54
I have a question on the inline 6 distribitor the one on my T2X which has the problem with all the stickey sealer draining out . I have a 150 merc dist. which I was going to use the sending unit and rotor asmb..but I see the plate that the sender sends threw has smaller openings. Was this a upgrade???
03-01-2012, 03:43 PM #153but I see the plate that the sender sends threw has smaller openings. Was this a upgrade???
Arne KjetilMy engines :
Johnson V4m-10s 90 hp 1964,from the prosess.
Mercury TII, next project
True story ??:-)
03-01-2012, 04:46 PM #154
You can change the disk ,just be careful not to break the rotor or the pickup. If the nut on the dist shaft doesn't want to come loose use a cordless impact driver while holding the rotor in a rag. I distroyed one trying other methods. The discs have a right side up ,so mark it to get it in the right possition.Arnes right about the difference in the cranks ,but I think the std engine only has 4 main bearings.Glen
03-01-2012, 05:13 PM #155My engines :
True story ??:-)
03-01-2012, 10:09 PM #156Member
- Jan 2008
- houston texas
- 54
I thank you for the info about the trigger disk I changed it to the one on the T2X .I had some trouble getting the nut loose but I used the impact driver method it worked great. Have it together and back on the motor. The timing belt I repaired with the nylon backing has bonded so well I dont see it coming apart it seems extremely strong and flexiable. I have pulled ,bent ,twisted next step is run it. I think as long as distribitor is free should be OK. Keep you posted Skeeter..
03-02-2012, 08:17 AM #157
Im going to run it on my Tunnel its an 86 sst60...the hull weighs approx 325lbs...The T2X came with a ssm with 14-15 gear ratio and the only prop I have is a 10+18 three blade..Im worried about running it on ths hull but its all I have...Skeet 2 keep up the good work!!..Hope it works well!! Glen thank you for the imput Im taking it all in this is a great site!!
03-02-2012, 09:40 AM #158Member
- Jan 2008
- houston texas
- 54
Spongebob . Give me a call 713-692 3682 skeet2
03-02-2012, 02:05 PM #159
Skeet2,hopefully your belt repair is sucessful, thats an impressive collection you have . Can you give us some of your setup specs for the TllX ,such as fuel pressure,jet size for your elevation ,carb model,timing , idle needle . I have a T-ll ,1250SBP, 1500 short shaft and a couple other I6s . At present I'm restoring my full nose 18' Molinari and running the T-ll on a 14' Cobra videos of both on u-tube under Baldad45.
03-02-2012, 02:06 PM #160
Skeet Ill give you a call tonight......Thanks
03-11-2012, 11:22 PM #161Team Member
- Jun 2003
- pa.
- 229
the ports on my t-2 are way bigger than any xs. which is the real reason it has more stuff. the carbs and front half need to coincide.
03-16-2012, 08:55 AM #162
Anyone have any good closeup pics of the exhaust ports on a T2-T2X ?
03-16-2012, 10:09 AM #163
Not the best picture... but I can take some pictures later as I got my T2 in parts...
True story ??:-)
03-16-2012, 01:50 PM #164
T2 ports
Thanks Arne , looks like it's into the top wall a little and the center ports squared . Also a good view of the intake ports showing the delay in the center port with its upward flow .
03-17-2012, 12:52 PM #165
True story ??:-)
