Results 1 to 6 of 6
    Sep 2002
    PSL, Florida!
    Downloadable Prop Calculators
    I was wondering if anyone has found downloadable prop calcs online. i have the on from the hydrostream registry at
    www.hydrostream.org
    but i was wondering if there are others out there.
    Don't lick my boat, It makes it sticky!
    Another Hitman for the Sunshine Syndicate!!
    2011 Seafox Viper
    Georgia
    6 Thread(s)
    Easy offsite picture hosting:http://www.tinypic.com/
    Home
    Not what you asked but the Aeromarine prop program is real nice. It's a lot better than any of the online calculators. Change one item and keep all the others without refilling them out.
    Not too bad on price. I think it's worth it.
    The RPM is a slider so you can just keep bumping it up to see the result. Shows both calculated and slip speed. You select the slip %.
    '90 STV
    '96 260
    under construction
    for far too long
    Ontario, Canada
    Thanks Techno
    ...Thanks for good words. The new upgraded (version 2.8) PropWorks2 calculator is even better than the original! We've had allot of great feedback from users...and added some of their suggestions...we've added a detailed database of over 750 engines from all the manufacturers, so you can easily retrieve the specs of your engine by just clicking on it. (For example, max RPM and gear ratio is automatically loaded for you). All the rest of the software operation works the same as it always has. And we're happy to hear suggestions from the users for improvements!
    UPDATE: We have now added all of the 2015 engine specs to PropWorks2 (V2.15) for 1750+ OEM engine specs.
    Jim, I saw you on Powerboat Television today (Speed channel). Great feature on tunnel boats!
    Facebook
    | YouTube | Vintage Outboard Catalogs
    Ontario, Canada
