Results 1 to 5 of 5
Thread: Johnson rev limiter
06-17-2003, 05:14 PM #1
Johnson rev limiter
I have a 150 Fast Strike and I seem to be having problems with the rev limiter "changing" One trip it will be at 5500rpm, and then you shut it down, start it back up and it will now hit the limiter at 4500rpm. Does anyone know why it will act like this and how to disable it. B.T.W. It is a 1995 model. Thank
you.2011 DCB F26
2017 300 XS DBR
06-17-2003, 09:58 PM #26000 RPM
- May 2001
- Summit,N.J./Lake George,N.Y.
- 1,189
check tach
Had the same problem with a 3 cyl looper turned out to be a incorrect tach reading caused by faulty charging system,check your charging volts/amps.
Rolf
06-18-2003, 08:59 PM #3
Can i take the rev limiter off?
Thank you Skydog2011 DCB F26
2017 300 XS DBR
06-18-2003, 09:26 PM #4
does it have
orng & orng/blk wires coming from front of stator?
if so unplug themDrew Virnelson
84 Checkmate
19'Exciter/Evinrude XP 2.6
best of 73.3 mps (gps)
gonna try for more this weekend!!!
06-18-2003, 09:35 PM #5
THANK YOU
I will look!!
2011 DCB F26
2017 300 XS DBR
