Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 36
    Sep 2017
    Saugatuck, Michigan
    Johnson 225, temp send unit install ??
    I have twin 89 Johnson 225 v6's....want to install electric water temperature sending units and gauges.
    Anyone have any input on where to drill and tap a sending unit ?
    Thermostat housing is pretty small....however that would be the ideal spot.
    Have a Lot on $ wrapped up in motors, the overheat buzzer means too late !
    Suggestions appreciated!
    Thanks, Bart
    Jul 2005
    AZ
    just to the side of the t-sat they are tapped just need to install the sending unit..trying to find a good pic
    '84 Checkmate Convincor
    Jul 2005
    AZ
    Sep 2017
    Saugatuck, Michigan
    can it be drilled out to connect to water passage or did you just install sending unit
    Sep 2017
    Saugatuck, Michigan
    by the way... your boat looks badass !
    Jul 2005
    AZ
    I just installed the sending units..used a pryometer to check temp and was spot on. . I didn't drill it out the sending unit bottoms out on it and IF I remember it's not that thick so...and thanks
    Sep 2017
    Saugatuck, Michigan
    What set up on your motors ?
    Jul 2005
    AZ
    The temp gauges or? Just some led digital ones, they are easier to read for me than my other gauges..
    Jul 2005
    AZ
    What year is that eliminator looks nice..how's it run with those motors and did you do anything to them?
    Sep 2017
    Saugatuck, Michigan
    1989 v6's
    Complete rebuilds
    .040 over...Swaines coated pistons
    CDI coil packs
    Just installed 2.7 heads rejected to 64D upper and 65D 5&6. Did not gut air box......yet !
    New CDI power packs
    Bob cones...28 Mazco RE wheels
    Only had the boat out 2 weekends end of sumner.....Ran good after some tuning.
    Steering was old and a little loosy-goosy.
    Didn't take it past 75. This was before mods listed above.
    Hope to wake these dinasours up a bit with the new heads.
    Sep 2017
    Saugatuck, Michigan
    Boat is 1988 23ft
    Just had all interior done...previous owner had boat gutted and resealed floor, new seat boxes, new Levorsi gauges and shifters....now on floor.
    Boat gel is in incredible shape. Looks new !
    Hull also perfect shape.
  12. #12
    Sep 2017
    Saugatuck, Michigan
    Looks like from your photos... you went with the purple theme as well...looks nice
  13. #13
    Jul 2005
    AZ
    Oh,
    -Cdi 8500 rpm digital ignitions..power packs,timing bases,stators, rectfiers,Harnesses everything..
    -Opened the exhaust from backs and lower units
    -Velocity stacks
    -rejetted (damn don't remember off the top of my head)
    -thinner head gaskets
    -Solid mounts.
    -and some other stuff..
    -have worked 26 choppers and 28 cleavers..
    Have been looking for 2.7 heads..but
    Have anymore pics of yours
  14. #14
    Sep 2017
    Saugatuck, Michigan
    Pics
    Attached Thumbnails Attached Thumbnails 20171020_145731.jpg   20171016_211422.jpg
  15. #15
    Sep 2017
    Saugatuck, Michigan
    Awesome set up those boys of yours should move
  1. how and where do i install temp probes for pyrometers in 2.5 260
    By aggiestckl in forum Technical Discussion
    Last Post: 08-30-2013, 08:55 AM
  2. Mercury Tech: Temp sendnig unit for Merc H-C gauge install question (contact block or just water)
    By bmcalpine in forum Technical Discussion
    Last Post: 07-15-2012, 05:21 PM
  3. best place to send a block for a sleeve install ?
    By WATERWINGS in forum Technical Discussion
    Last Post: 04-20-2012, 07:23 PM
  4. Who can I send a 75 hp Johnson Stinger to for modification?
    By john rowley in forum Technical Discussion
    Last Post: 06-22-2010, 08:00 AM
  5. trying to re-install lower unit,,,help...
    By Budlight in forum Technical Discussion
    Last Post: 08-11-2007, 02:16 PM
