Results 1 to 6 of 6
    Discoloured metel reeds , what is the cause
    Just took a reed housing apart and found the reed leafs are discoloured !!! the reeds in question are original metal reeds in a 1995 omc 56 ci motor.
    I have not seen this before, the metal is stained / etched and I am wondering what causes this.
    is this what todays fuel does to the metal ? or is there something else going on.
    the motor gets run on normal pump gas at 50 to 1 on mercury premium 2 stroke oil.
    here is a pic of the reed leaf to show what I mean, you cannot get the stain off the leaf its like sort of burnt in like its been etched...
Name:	reed leaf 2x.jpg
ID:	397347Click image for larger version.
Name:	reeds leaf 1x.jpg
    Jun 2009
    central minnesota
    put an unmarked one in and I bet it stays the same,betten the stained reed was that way from the getgo-th
  3. Thanks phillnjack thanked for this post
    I di not even think about them being like that from new, bit of a poor show if that is the case...
    but in the mid 90's omc didn't take a lot of care about a lot of bits n pieces in these motors, so your probably right..
    Sep 2016
    McHenry,Illinois
    Can't imagine them being like that since new...you can see the stained edge around where the reeds touch the reed cage...seems odd that they would be stained with that shape before even being installed. Could possibly be some sort of coating that was not cleaned off before installation and was "baked" on somehow? I too have never seen that on any reeds I've removed.
    Hustler 15' Wildcat / Merc 80
    Hustler 13' Wildcat / Merc 80
    Hustler 13' Picklefork (Experimental) / Merc 80
    Hustler 16' Victor / Evinrude 85
    Hustler 15' Tunnel / Evinrude X115
    Hustler 17' Lark / Suzuki 140
    Ranger 17' Aztec / Merc 115
    Hustler 16' Victor
    Hustler 16' Victor / JohnRude 135 (current and restored)
    Hustler 15' Family Tunnel / Johnson GT115 (current project)
    Hustler 16' Victor
  6. Thanks phillnjack thanked for this post
    Likes phillnjack liked this post
    Salty?
    they had a very slight film of oil on them but a lot drier than I would of expected.
  1. Replies: 18
    Last Post: 04-05-2022, 05:35 AM
  2. Mercury Tech: fiber reeds and steel reeds in same motor
    By buzmacdowell in forum Technical Discussion
    Last Post: 07-09-2011, 10:06 PM
  3. horizontal reeds v/s vertical reeds?
    By david martin in forum Technical Discussion
    Last Post: 12-04-2007, 06:09 AM
  4. BOYESEN REEDS VS LAND & SEA REEDS
    By MrCougar in forum Technical Discussion
    Last Post: 05-14-2001, 07:08 AM
