Results 1 to 9 of 9
01-15-2018, 03:37 PM #1
Reverse gear spacer fatshaft torque master
Ok, you l/u gurus. I'm replacing a fat shaft on a 3.0l torque master. The reverse gear spacer is damaged slightly and doesn't come off old shaft. I ordered a new spacer to find it doesn't slip over splined section either. Looks like it's correct and would fit on the lower section with the smaller I/D of shaft, just won't go over larger splined end. My question is do you heat it or something to make it larger so it'll go over splined area or am I loosing my mind and not get the right spacer? Or both?
01-26-2018, 01:17 PM #2
To answer my own question in case others run across this. The fatshaft torque master for 3.0 liter part number for the reverse gear spacer is 23-824108-1, they sent me a 23-824108 without the 1 on the end and this is the standard small shaft spacer.
01-27-2018, 10:27 AM #3
It took you long enough to answer that question: ! Tighten up. Mike
Cheaters never Win !!!
01-27-2018, 11:11 AM #4
Yeah lol, I looked it up again and realized the price on the part # I looked up was about $40 higher than the one I recieved and figured something had to be wrong . It still bothers me old one still don't come off old shaft though, hope it's just out of round a little from catastrophe. We'll see next week. If it don't go over splines out comes the heat
01-30-2018, 03:50 PM #5
Welp, got the other spacer in today and fits over the splines just fine, imagine that.
01-30-2018, 04:37 PM #6
Who wuuda thunk it!
Speaking of spacers , can off-road or fx4 front ifs be converted to coil springs or coil overs from the torsion set up ? Thanks mikeCheaters never Win !!!
01-30-2018, 06:26 PM #7
I've never done one, i think Rock Krawler makes a kit, but ain't cheap and couldn't actually find one when I searched. All you would need would be a coil over strut to replace the stock shock with I would think and remove the torsion bar. I don't see why not with a little fabrication and modification. What you up to anyway, wanting to do that? Need to get that mota built and get us a good riding group together so we can break in these new ticking time bombs
01-30-2018, 09:55 PM #8
Sitting in a stand with plenty of time to think !
01-30-2018, 10:12 PM #9
Oooo that gets expensive . Best time to concoct up serious projects though.
Anyone have a 3.0 fatshaft reverse gear laying around?
By baja200merk in forum Bass Boats and Sport Fishing RigsReplies: 2Last Post: 01-05-2017, 10:21 AM -
3.0 torque master 1.75 20 inch fatshaft
By ckp73 in forum Lower UnitsReplies: 1Last Post: 12-12-2015, 12:00 PM -
Do they make a 1.62 gear for the torque master??
By gamblerman01 in forum Lower UnitsReplies: 2Last Post: 12-09-2015, 06:18 PM
