Results 1 to 9 of 9
01-14-2018, 08:50 PM #1Member
- May 2017
- Shawano, WI
- 35
Mercury Ignition Coil Suggestions???
Looking for advise on ignition coils. Need to replace some on my 2.5 260 and was wondering if the CDI brand or Sierra brand are ok to use and are reliable. Mercs seem to be a little expensive. Any thoughts would be helpful. Thanks
01-16-2018, 11:12 PM #2
All I can tell ya is that I just replaced all my coils with new sierra parts off ebay and they seemed well made - $30ish each so I can't complain!
I have sierra stator and CDI triggers and switchboxes on my motor - I think most people in here seem to be perfectly happy running either brand's gear
01-20-2018, 06:52 PM #3
I've learned there is pretty much no difference unless the manufacture shows you the volts, ohms, bla bla bla so you can compare both yourself.
I just go with CDI because my other parts ended up being CDI and CDI sometimes don't like to cover parts if your using brand A with Brand B with Brand C.If I don't ask any questions, I'll never learn anything.
01-20-2018, 07:04 PM #4Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
CDI was working on a new coil last year that is probably available now. I think it could be a bit hotter from what I remember.
01-30-2018, 12:02 AM #5Member
- May 2017
- Shawano, WI
- 35
Thanks for the info guys.
08-07-2018, 04:08 PM #6Member
- Dec 2010
- Denmark
- 98
- 9
I installed 6 new CDI coils (P/N: 184-0001) on my Mercury 260HP outboard last year, and they worked fine until this spring.
The first one was fried during the first trip this spring. It worked fine on the way out, but on the way return it lost 200rpm in when idle. And was some difficult to start. When I tested the spark, there was no spark on one. I thought that it was one of a million, and put one of the old blue one on. Then I went on a trip a couple of weeks ago, and now the secone one died. So now I have put the good old blue stuff on again.
The reason for replacing the blue once, was because some of the core was cracked on some of the old one.
So I am not so happy with the CDI one.
08-07-2018, 11:33 PM #7
I think Sierra bought Mallory (prufex) which were made in Germany.These are decent and make "hencho in mexico" mercury ones look like crap..they do have diff resistance on secondary windings tho..I tried them and they did jump a 1/2" airgap no prob!!
"Whacker Smacker" #561 IHBA M/E div1 2007& 2006 first looser champion
2007 Sportsmen Driver of the Year
08-09-2018, 02:29 PM #8Member
- Mar 2018
- Wheeling, WV
- 39
- 10
Would you have the sierra coil P/N for the 260/280s?
08-12-2018, 09:08 AM #9
sierra 18-5186
304Mirage liked this post
225 opti ignition coil problem
By Tpower in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 2Last Post: 05-12-2010, 01:57 AM -
ignition coil test?
By stvhelm in forum Technical DiscussionReplies: 11Last Post: 08-31-2003, 09:59 AM -
merc. ignition coil vs. hi-po coils
By BRENT GILL in forum Technical DiscussionReplies: 16Last Post: 03-06-2003, 04:50 PM -
225 ProMax Ignition Coil Values?
By RED ALERT in forum Technical DiscussionReplies: 2Last Post: 09-03-2002, 10:57 PM
