Results 31 to 45 of 71
Thread: Reed Stoppers
01-19-2018, 02:37 PM #31
on mine they are on both sides, I only have a omc 56 .. both sides are the same on this.
01-19-2018, 02:52 PM #32Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,272
- 215
- 30
- 585
spybot liked this post
01-19-2018, 02:53 PM #33
I was on the understanding that the " reed stopper" was not intended to limit reed opening but acts as a damper.???
Popey
01-19-2018, 04:05 PM #34Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
HeeHee
In the old ...dazzz,,,kg9 mk 20 had the crank spinning past the reeds. Need a stop. Or crank got in a game of hittman ... Later L6 had stops but 2 different styles. one had a break point the other had a smoth tranisiliton. Sorry for sp/, old motors need stops......
01-19-2018, 04:08 PM #35
01-19-2018, 04:14 PM #36Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
The good five panel Chryslers from the 70s are the same style with the curve stop and shim strip. When using aftermarket reeds the stop not used , the strip is. No issues at all doing this except a gain in rpm, for this application. About 2.8+ square inches for the later Force five panel.
01-19-2018, 04:50 PM #37Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
Shimm used a breck point.
01-19-2018, 08:45 PM #38
" Shimm used a breck point "
what is that supposed to mean ?
01-19-2018, 09:37 PM #39
Just got done putting my new CCM reeds in my Johnson 1975 135...it had no shims but did have stoppers which I reused while installing the new reeds. Is there a rhyme or reason on when the shims were used and when they were not? The only reason I changed the reeds is that I don't want to destroy a 42 year old engine by sucking a steel reed. Also my old reeds didn't have any of that weird staining shown in an earlier post.
Hustler 15' Wildcat / Merc 80
Hustler 13' Wildcat / Merc 80
Hustler 13' Picklefork (Experimental) / Merc 80
Hustler 16' Victor / Evinrude 85
Hustler 15' Tunnel / Evinrude X115
Hustler 17' Lark / Suzuki 140
Ranger 17' Aztec / Merc 115
Hustler 16' Victor
Hustler 16' Victor / JohnRude 135 (current and restored)
Hustler 15' Family Tunnel / Johnson GT115 (current project)
Hustler 16' Victor
01-20-2018, 08:39 AM #40
are your 135 stoppers the ones with the 3 slots or the complete plates ?
01-20-2018, 10:50 AM #41
My stoppers have the slots cut in them...although I have seen the solid plates before.
Hustler 16' Victor
Hustler 16' Victor
01-20-2018, 11:20 AM #42
slotted stops are the original ones fitted to the 135.
with the original metal stops the reeds could no way get bent enough to cause metal fatigue.
newer reed material lets the reeds move more easily, but it would seem that modern materials dont last as long.
Or are these newer reeds only lasting a short time due to the motors being modified for a much higher rpm ?
if the rpm was kept down to say 6,000 to 6,500 rpm as per fishing motor, how long would newer type reeds last ?
01-20-2018, 12:31 PM #43
01-20-2018, 01:06 PM #44
Just an opinion but i really don't like the solid plate stops for several reasons, A. they have to produce some kind of dampening effect as the volume on the back side between the reed and solid plate has no where to vent except the ends.. B. They have allot of oil/gas weted surface for them to stick to which you would think could slow the recoil on closing.. C. the intake charge drawn into the case between the petals is restricted.. Just my own theory but why i have never liked them..
01-20-2018, 01:13 PM #45
I emailed Chris about what reeds to use and he recommended the 144R reeds. It appears they sell 3 different types...S, R and D...standard,race and drag. Now I'm curios how long these reeds will last and should I have gone with the "s" type. This is not going to be a race boat but I'm going to try to run this motor at the upper RPM limits...prolly 5800 - 6200 RPM.
Hustler 16' Victor
Hustler 16' Victor
Mercury 7 peddle reed plate, 1" spacer and reed blocks
By tgreen in forum Misc. Parts and AccessoriesReplies: 1Last Post: 02-01-2016, 07:27 PM -
Mercury Tech: Clamshell Cowl from vertical reed , need to use on a horizontal reed engine. How?
By Zoomba in forum Technical DiscussionReplies: 0Last Post: 04-25-2015, 11:17 PM -
5 pedal reed plate carb and EFI different size reed openings???
By kyleweeky in forum Technical DiscussionReplies: 1Last Post: 01-30-2015, 01:46 AM -
Yamaha Tech: TDR/reed stoppers
By DoktorC in forum Technical DiscussionReplies: 4Last Post: 08-18-2009, 05:40 AM
